Flexviewer 2.3.1 code source
1466
5
10-13-2011 08:46 AM
RenaudZambeaux1
I need to modify a application made with the flex viewer 2.3.1, but I don't have the source code. (flexviewer-2.3.1-src.zip file).
Does anyone know  where I can find it ?
RZ
SchoppMatthieu
SchoppMatthieu
Nop, sorry, that's the compiled version...
I've got a copy of the 2.3.1 (2.3 MB, so too large to be attached).
How can I send it to you ?
Also if you don't have the source code for the application you need to modify, you will have to start it from scratch.
So why not starting with latest version (FV2.4) ?
RenaudZambeaux1
Hello Matshop,
Thanks for your reply.
Actually, the application is already made with 2.3.1 viewer, but only xml files have been modified.I have to modify the code (or try to do so), because I need my TOC (MapswitcherWidget) to  have RadioButton that act as mutually exclusive control.  By the way, if you know how to do that...!
So I think I don't need to migrate the application to 2.4.
Could you send me the source code to this adress: [email protected]
Many thanks
Renaud
SchoppMatthieu
Hello Renaud,
I sent it through,
Regards,
Matt
H_JamesWorley_III
I am wanting the source code also for Flex Viewer 2.3.1 also.  I am deploying in a secure environment and believe 2.3.1 will work better.  I tried upgrading to 2.4 however some of the functionality I had in 2.3.1 doesn't work with 2.4.  Is there anyone out there that still has it un-compiled?
v/r
Jim Worley
[email protected]
