intersect widget using geoprocessing service
1524
03-25-2014 06:37 AM
fatizanady
hi everyone,
does anyone have any idea about how to develop an intersect widget using geoprocessing service?????
Thanks for any help that could be offered!
BjornSvensson
Esri Alum
You could also use the intersect() method of the GeometryService
https://developers.arcgis.com/flex/api-reference/index.html?com/esri/ags/tasks/GeometryService.html&...
KomanDiabate
Yes, you will be a lot better off using geometry services.
private function SelectPoints(queryGraphic:Polygon):void
    var query:Query=new Query();
    var queryTask:QueryTask = new QueryTask();
    queryTask.url = "http://****/sdgis/rest/services/*************/0";
    query.spatialRelationship=Query.SPATIAL_REL_INTERSECTS;
    query.geometry=queryGraphic;
    query.outFields=["*"];
    query.returnGeometry=true;
    queryTask.execute(query, new AsyncResponder(onResult, onFault));
    function onResult(featureSet:FeatureSet, token:Object=null):void
     for each(var myGraphic:Graphic in featureSet.features)
      myGraphic.symbol=sfs;
      myGraphicsLayer.add(myGraphic);
     Alert.show(featureSet.features.length.toString())
    function onFault(info:Object, token:Object=null):void
     Alert.show(info.toString());
fatizanady
bjorn,kdiabate64,
Thank you very much for answer.
Indeed, I have to work with geoprocessing services because it's the topic of my graduation project.so i well just use the geoprocessing service :).
Thanks again 🙂
KomanDiabate
Well, in that case good luck.
