Infowindow MouseOver
1306
11-10-2010 04:03 AM
MayJeff
Can someone show me how do you do this new sample by using flex builder 3?
http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=FeatureLayer_MouseOver_Snapshot
Thank you.
May
DasaPaddock
ArcGIS API for Flex 1.x doesn't have a FeatureLayer, but you can do the same thing by using a QueryTask and a GraphicsLayer.
MayJeff
I attached the file based on your sugguestion but I am not able to figure out why all the parcels polygon not show up.
Please help.
Thanks.
DasaPaddock
That service has a max limit of 500 features that it will return per request.
MayJeff
If service only return 500 max. records so do you have to zoom close to the layer in order to get mouseover function to work.  I found this site-(http://ags.cdm.com/windsorlocksct/) and I would like to have the same function like this site to use mouseove on parcel:
Can you show me how to make this to work in order to use mouseover to identify the parcel?
Thanks.
