How do you recover a .swf file for a widget?
1301
5
09-02-2010 07:14 AM
JoshuaCoates
I accidentally deleted the search widget .swf file from my project. Is there a way to find this file and download it? I looked in the original flexviewer folder, however, I do not see any .swf files in any of the widget folders in the src directory?!
RobertScheitlin__GISP
Joshua,
   Swfs are compiled versions of the mxml code so you should never see swfs in the src directory. Look in the bin-debug or bin-release folder to find the compiled swfs.
JoshuaCoates
I only have a bin-debug folder and I did not see the search widget .swf in there? I actually deleted the file itself out of the project folder...not just from inside FlashBuilder....whooops?! I see the other widget .swf's in the other folders...just not in the search widget folder.
Joshua,
   If you have the SearchWidget.mxml in the src folder than when you run or debug your project it will rebuild the swf.
JoshuaCoates
Ok well I just rebuilt the whole project and its fine now. However, why is it that occasionally when I run my project...the background to my map is black like the entire UI? It is usually white but sometimes it appears all black and if I hit refresh enough it will go back to white?
GeorgiannaStrode
Does any one knows how to import the project into Flex builder 3? I can not even import the project (which is the widget folder) into it, so that makes me impossible to run a mxml file correctly. I also wonder how exactly does the Flex builder compile the mxml to swf file, since I've never seen it created a swf file automatically just by running the mxml file.
Looking forward to your help!
