imagery catalog web template
703
11-01-2012 02:22 PM
Muahmmad_HamadZahoor
Hi all.
any one of u using image catalog web template???
http://www.arcgis.com/home/item.html?id=00e0efc3ab0f41cdbf572929a93655f6#!
I am installing ICW(Image catalog web template) on my machine.
I have problem regarding its installation and configuration.
After installing it on server.the configuration has to be done in config file.but that is not containg all the configurations and even if run the application on the system with out configuration of localserver with internet that runs..its configuration file does not contains all the configuration data to set.......that my be in the flex code???Either I have to download the source code and to make changes in that or there is some better way???
And from where the source code can be downloaded??online compiled application is available.
Any expert opinon???The feedback will highly appriciated
Regards
Hamad
