Identify features to new view in mobile app
1096
08-22-2011 04:05 AM
raffia
Dear all;
Am using Flex 4.5.1 on Win XP, mobile project. A simple identify function that identifies polygon landmarks in the map and send the identify results to a new view, and it is driving me crazy. To send variables to a new view, I used this technique
http://devgirl.org/2011/08/09/flex-mobile-development-passing-data-between-tabs-part-2-includes-sour...
Then modified it every which way to no avail.
Main App relevant code:
   import model.landmarks;
   import views.landmarkDetailsWindow;
   [Bindable]
   public var landmarksVar:landmarks = new landmarks();
landmarks.as code:
package model
 [Bindable]
 public class landmarks
  public var type:String;
  public var name:String;
  public function landmarks()
   this.type = type;
   this.name = name;
First View relevant code, where the identify happens:
   [Bindable]private var lastIdentifyResultGraphic:Graphic;
   var clickGraphic;
   private function identifyClickHandeler(event:MapMouseEvent):void
    myMap.extent = new Extent(31.192271, 30.043800, 31.219662, 30.073615, null);
    var identifyParams:IdentifyParameters = new IdentifyParameters();
    identifyParams.returnGeometry = true;
    identifyParams.tolerance = 3;
    identifyParams.width = myMap.width;
    identifyParams.height = myMap.height;
    identifyParams.geometry = event.mapPoint;
    identifyParams.mapExtent = myMap.extent;
    identifyParams.spatialReference = myMap.spatialReference;
   identifyTask.execute(identifyParams, new AsyncResponder(myResultFunction, myFaultFunction, clickGraphic));
   private function myResultFunction(results:Array, clickGraphic:Graphic = null):void
    var identWinVar:DE_Mobile_App = parentDocument as DE_Mobile_App;
    landmarksVar = identWinVar.landmarksVar;
     if(result.layerName == "Landmarks")
//////The following lines is where I attempt to send the data identified (Type and Name) to the second view
     landmarksVar.type =result.feature.attributes["Type"].toString();
     landmarksVar.name =result.feature.attributes["Name"].toString();
     navigator.pushView(landmarkDetailsWindow);
   private function myFaultFunction():void
 <esri:Map id="myMap">
  </esri:extent>
  <esri:ArcGISTiledMapServiceLayer
          url="http://arcgis2.roktech.net/ArcGIS/rest/services/DigitalEg/English_Layered/MapServer"/>
 </esri:Map>
 <s:Button label="Ident" click="myMap.addEventListener(MapMouseEvent.MAP_CLICK, identifyClickHandeler)"/>
Code for landmarkDetailsWindow:
 <fx:Script>
  <![CDATA[
   [Bindable]
   public var landmarksVar:landmarks ;
 </fx:Script>
 <s:VGroup>
 <s:Label  text="Type:"/>
 <s:Label  text="{landmarksVar.type}"/>
 <s:Label  text="Name:"/>
 <s:Label  text="{landmarksVar.name}"/>
 </s:VGroup>
When debugging, you see that identWinVar.landmarksVar.type and .name are assigned the proper values when a landmark polygon is identified...
I also tried replacing this line
with
identWinVar.landmarksVar.type =result.feature.attributes["Type"].toString();
to no avail. Thanks in advance.
DarinaTchountcheva
Hi Raffi,
My Flex is getting kind of rusty, and you know I haven't done anything mobile, but here are some links that might help  you:
http://help.adobe.com/en_US/flex/mobileapps/WSa122979b4619725672e48c412a3e152164-7fff.html#WSe11993e...
http://cookbooks.adobe.com/post_Passing_data_between_Views-18854.html
P.S. I just open your link, you are using the second approach. Have you tried the first (which is explained in the links above):
http://devgirl.org/2011/08/09/flex-mobile-development-passing-data-between-tabs-part-1-includes-sour...
DarinaTchountcheva
Raffi,
In the links above, I see a second parameter to the pushView method, which is the data that you want to pass.
Maybe, this what you are missing.
Another link:
http://www.unitedmindset.com/jonbcampos/2010/10/25/flex-4-5-mobile-development-post-burrito/
Good Luck!
raffia
Thank you very much, as always, Darina 🙂
Raffi,
Another link:
Good Luck!
