Identify features in NavMenu
2820
12
08-02-2010 11:58 PM
ManuelFrias
From the code Robert shared some time ago (http://gis.calhouncounty.org/SFVDemo) I am using the NavMenu which provides a shortcut to the navigation buttons.
I would like to add a new button which would mimic the IdentifyWidget. I added a new public static const to SiteContainer.mxml
  public static const WIDGET_SHOW_INFO:String    ="widgetShowInfo";
which will then call the  public static const SHOW_INFOWINDOW in AppEvent.as
What I find tricky  is how to make the infoData object.
var infoData:Object =
         *          icon: icon,              //a Image object
         *          title: "a title string",
         *          content: "a string",
         *          link: "http://a.url.com",
         *          point: point,            //a Point object
         *          geometry: geom           //a Geometry object
I looked at IdentifyWidget.mxml and thought I would try to replicate everything in there.
Is there an easier way or should I just go on?
Manolo
ManuelFrias
Hi Robert,
Almost! That code identified the visible layer but it returned an error "invalid layer specified" six times (I have seven map services).
Then I added the following line:
if (identifyLayerOption == "visible" && dynamicLayer.visibleLayers.length > 0)
and I don't get the error but now it identifies all layers in the one map service. The service where there is one visible layer 😞
Manolo
ManuelFrias
I got it,
I removed the "invalid layer specified" error by commenting out Alert.show in function onFault. I don't know why this error appeared but it might be because I had modified the MapMapneger to show the cursor when clinking on a button.
Then it identified also my tiled layers which I didn't want to. I solved it by assigning "" to url when a tiledLayer was identified.
I attached the final mxml for those who want to experiment/improve/use it.
Thank you Robert for pointing me in the right direction.
And now, how do I assign your points? Don't tell me is not ready yet in this new forum.
Manolo
RobertScheitlin__GISP
Manolo,
   Yep, they don't have it worked out yet so just remember to come back later when they do.
