Identify features in NavMenu
2832
12
08-02-2010 11:58 PM
ManuelFrias
From the code Robert shared some time ago (http://gis.calhouncounty.org/SFVDemo) I am using the NavMenu which provides a shortcut to the navigation buttons.
I would like to add a new button which would mimic the IdentifyWidget. I added a new public static const to SiteContainer.mxml
  public static const WIDGET_SHOW_INFO:String    ="widgetShowInfo";
which will then call the  public static const SHOW_INFOWINDOW in AppEvent.as
What I find tricky  is how to make the infoData object.
var infoData:Object =
         *          icon: icon,              //a Image object
         *          title: "a title string",
         *          content: "a string",
         *          link: "http://a.url.com",
         *          point: point,            //a Point object
         *          geometry: geom           //a Geometry object
I looked at IdentifyWidget.mxml and thought I would try to replicate everything in there.
Is there an easier way or should I just go on?
Manolo
RobertScheitlin__GISP
Manolo,
   I think that you are on the right path. Do you need any specific help?
ManuelFrias
Hi Robert,
yes, I would need some help (see attached file).
I think my problem is that when I define the variable map:
private var map:Map;
map doesn't get all the layers and I get the error "Cannot access a property or method of a null object reference" here:
map.addLayer(graphicsLayer);
If I initialize the variable (private var map:Map = new Map) the error disappears but map doesn't get any layers.
I've been looking what IdentifyWidget does and there there is no map definition since it gets it from BaseWidget.as. But how does it add all the layers? I don't find it.
Manolo
Manolo,
  If it is just the map then just do this
private var map:Map = SiteContainer.getInstance().controller.map;
ManuelFrias
I still get  "Cannot access a property or method of a null object reference." because map is null, I guess.
Manolo
Manolo,
Attach your updated code so I can see what might be going wrong.
ManuelFrias
Hi Robert,
here you are the code with your suggestion.
Manolo
Manolo,
  Here you go the issue was that the mapmanager had not created the map yet when we were calling for it.
ManuelFrias
Thanks Robert!
I could hardly have figured out myself.
I wonder if you know where I can get the visible layers? I tried to get the LayerIds property of identifyParams and then assign the visibleLayers
identifyParams.layerIds = dynamicLayer.visibleLayers.source;
but that doesn't work (see attached code). I did something similar in my IdentifyWirdget.mxml and worked out fine.
Manolo
Manolo,
   Try this:
private function identifyFeatures():void
    var identifyParams:IdentifyParameters = new IdentifyParameters();
    identifyParams.returnGeometry = false;
    identifyParams.tolerance = identifyTolerance;
    identifyParams.geometry = identifyPoint;
    identifyParams.width = map.width;
    identifyParams.height = map.height;
    identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE;
    identifyParams.mapExtent = map.extent;
    for (var i:Number = map.layerIds.length -1; i >= 0; i--)
     identifyParams.layerIds = null;
     var layer:Layer = map.getLayer(map.layerIds);
     var url:String;
     if (layer.visible)
      if (layer is ArcGISDynamicMapServiceLayer)
       var dynamicLayer:ArcGISDynamicMapServiceLayer = layer as ArcGISDynamicMapServiceLayer;
       url = dynamicLayer.url;
       if(identifyLayerOption == "visible")
                      identifyParams.layerOption = "all";
                      if(dynamicLayer.visible == false)
                       url="";
      else if (layer is ArcGISTiledMapServiceLayer)
       var tiledLayer:ArcGISTiledMapServiceLayer = layer as ArcGISTiledMapServiceLayer;
                     url = tiledLayer.url;
                      if(tiledLayer.visible == false)
                       url="";
      if (url)
       var identifyTask:IdentifyTask = new IdentifyTask(url);
       identifyTask.addEventListener(IdentifyEvent.IDENTIFY_COMPLETE, onResult);
       identifyTask.addEventListener(FaultEvent.FAULT, onFault);
       identifyTask.execute(identifyParams);
