I am beginner for ArcGIS API for Flex
1518
6
12-03-2012 10:20 PM
HanibalLektor
I am beginner for ArcGIS for Flex...
What is my first step for ArcGIS for Flex.
There are videos tutorial for this.
Can you help me?
Best regards...
Chapy
MarcinDruzgala
You can start here: Flex in a week tutorial. It was very helpful for me when I started with flex.
Next go to: Arcgis Flex Samples A lot of samples for flex, simple applications with source code:)
Good luck!
Regards
MDruzgala
PierreLarondelle
Hi everyone, I run through the same problems as Chapy ...
Tutorials may be found here and there (adobe obviously) but it's sometimes very difficult for a self-taught person to achieve his firsts codings without extra help of daily developpers. Sewing together pieces of code from several origins may lead to surprising results 😉
On the contrary, I understand well that it may be boring or time consuming for skilled peoples to answer really basic questions but if you don't learn fishing to somebody, he will never be able to fish on it's own and will repeatedly ask for food ...
As an example, I'm simply wondering how to retrieve a specific layer in a map service to query it in a widget and return a symbol on top of the map service (very basic local geolocator). As I'm totally newbie thus not so skilled as most of you (and /or dumber maybe ... 🙂 ) I don't figure out wich classes are involved, etc ...
I've spend some times on looking inside the code of existing widgets but the clue didn't spring out clearly until now, nor I didn't find an answer on another flex related site. What a newbie need is something like "to retrieve value from a feature layer's field use the retrieveValueFromASpecificLayer class (e.g.) as data provider". Maybe it's not the best way to code it but it gives a starting point allowing the widget to work, even not perfectly, showing some results and wheting the appetite for learning better practices.
Anyway, thanks a lot for any help it's always welcome and really appreciated.
Have a nice day folks !
Pierre.
HanibalLektor
I know for resource Arcgis API for flex. I have video for flex from Adobe.
But, i am interested video training for arcgis api for flex.
How to install, haw to start with my data and how to create web gis application with my data use arcgis API.
Thank you...
Chapy
MarcinDruzgala
Thank you...
Chapy
Google is your friend then..
Quick links:
http://resources.arcgis.com/en/communities/flex-api/ -on the right side you have Download & Install.
Just read all you can find there. You have featured videos, recent blog posts and recent forum post...
Cheers
MDruzgala
IvanBespalov
Google search video results for "arcgis api for flex getting started"
http://video.esri.com
HanibalLektor
Thank you for help.
Now, step by step.
Chapy
