Hyperlink in search result
2976
03-12-2014 11:25 AM
RudieWatzig
Hello, I hope I am posting in the correct forum.
I am very very new to the FLEX api, and I have a very simple question.  Actually, there are about 3 things I need to figure out, but I will do one at a time.
I am using the Application Builder version 3.6.  I would like to get my search widget to display the result as a hyperlink, not just plain text.  See attached photo for example:
[ATTACH=CONFIG]32156[/ATTACH]
I imagine I Will have to change this option in my config file somehow?
            <textsearchlabel>Select by attribute</textsearchlabel>
            <titlefield>Name</titlefield>
            <fields>
                <field name="Name" alias="Name"/>
                <field name="Link" alias="Link"/>
            </fields>
            <orderbyfields>Name ASC</orderbyfields>
        </layer>
    </layers>
</configuration>
Thanks for your help.
AnthonyGiles
Honored Contributor
Rudie,
You need to use the linkfield tag in your layers:
<linkfield alias="More Information">Link</linkfield>
See the help here:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Search_widget_tags/01m300000023...
Regards
Anthony
AnthonyGiles
Honored Contributor
Rudie,
See the help here:
Regards
Anthony
RudieWatzig
Thank you.  Like I said, I'm just figuring this stuff out TODAY.  It worked.
