<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:esri="http://www.esri.com/2008/ags"
      pageTitle="World Street Map">
 <fx:Script>
  <![CDATA[
   import com.esri.ags.Graphic;
   import com.esri.ags.SpatialReference;
   import com.esri.ags.events.GeometryServiceEvent;
   import com.esri.ags.events.MapEvent;
   import com.esri.ags.geometry.Geometry;
   import com.esri.ags.geometry.MapPoint;
   import com.esri.ags.symbols.SimpleMarkerSymbol;
   import mx.controls.Alert;
   protected function map1_loadHandler(event:MapEvent):void
    //project the lat and long values from 4326 to 102100
    var myPoint:MapPoint = new MapPoint(-122, 73, new SpatialReference(4326));
    geometryService.project([myPoint as Geometry], new SpatialReference(102100),null);
   protected function geometryService_projectCompleteHandler(event:GeometryServiceEvent):void
    var pt:MapPoint = (event.result as Array)[0]as MapPoint;
    var myGraphic:Graphic = new Graphic(pt, new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933));
    myGraphicsLayer.add(myGraphic);
    map.centerAt(pt);
 </fx:Script>
 <fx:Declarations>
  <esri:GeometryService id="geometryService"
         projectComplete="geometryService_projectCompleteHandler(event)"
         url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/>
 </fx:Declarations>
 <esri:Map id ="map" load="map1_loadHandler(event)">
  <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
  <esri:GraphicsLayer id="myGraphicsLayer"></esri:GraphicsLayer>
 </esri:Map>
</s:Application>
               pageTitle="World Street Map" xmlns:mx="library://ns.adobe.com/flex/mx">
    <fx:Script>
        <![CDATA[
            import com.esri.ags.utils.WebMercatorUtil;
//                geometryService.project([myPoint as Geometry], new SpatialReference(102100),null);
                var myGraphic:Graphic = new Graphic(WebMercatorUtil.geographicToWebMercator(myPoint), new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933));
                map.centerAt(myGraphic.geometry as MapPoint);
//            protected function geometryService_projectCompleteHandler(event:GeometryServiceEvent):void
//                var pt:MapPoint = (event.result as Array)[0]as MapPoint;
//                var myGraphic:Graphic = new Graphic(pt, new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933));
//                myGraphicsLayer.add(myGraphic);
//                map.centerAt(pt);
    </fx:Script>
    <fx:Declarations>
    </fx:Declarations>
        </esri:Map>
</s:Application>
