how to a wfs service to the <esri:Map> component?
707
01-13-2012 02:17 AM
liTao
like the title , how can i add a wfs service to the <esri:Map>,so it can show the layer like it added to ArcMap?
RobertScheitlin__GISP
Li,
   There is no native WFS support in the API. Here is the something that might interest you though:
http://arcscripts.esri.com/details.asp?dbid=16191
liTao
thanks for your reply �?the context in your url  really do much help for me ,but the version is based 2.0 api and sdk 4.5,
specially, the maplib package .so how can get all source code ,so that i can change them to 2.5 api and sdk4.5.
samirshamaa
hi li,
i am in a similar situation, i want to add a WFS service in flexviewer 2.5
did you get the source code ?
thanks,
Li,
  As I mentioned WFS is not supported natively in the API so it is your responsibility as a developer to take the source code in the link and migrate it to Flex 2.5 API, if you want to use it...
liTao
Li,
yes,i see.it is just my responsibility!
thank you very much.
