Help! Can't show infoWindow
1099
03-14-2012 02:54 AM
sherlytobias
<fx:Script>   <![CDATA[    import com.esri.ags.Graphic;    import com.esri.ags.SpatialReference;    import com.esri.ags.events.GeometryServiceEvent;    import com.esri.ags.geometry.Geometry;    import com.esri.ags.geometry.MapPoint;        import mx.collections.ArrayCollection;    import mx.rpc.AsyncResponder;    import mx.rpc.events.ResultEvent;        import spark.components.TextArea;            private function init():void    {     pointsXML.send();    }    protected function pointsXML_resultHandler(event:ResultEvent):void    {     var gArr:Array = [];     var myGraphics:Array = [];     var x:XML = XML(event.result);     var pntList:XMLList = x..entry;     for (var i:int = 0; i < pntList.length(); i++){      var latlong:Array = pntList.point.split(" ");      var attrib:Object = pntList.name;            var myPoint:Geometry = new MapPoint(latlong[1], latlong[0], new SpatialReference(4326));            var coordGraphic:Graphic = new Graphic(myPoint);            gArr.push(myPoint);      myGraphics.push(coordGraphic);     }     var outSR:SpatialReference = new SpatialReference(3857);     geometryService.project(gArr, outSR, new AsyncResponder(projectCompleteHandler, null, myGraphics));             var textArea:TextArea = new TextArea();     textArea.height = 50;     textArea.width = 100;     textArea.text = attrib.toString();     map.infoWindow.content = textArea;    }                protected function projectCompleteHandler(result:Object, token:Object):void    {     var pRslts:Array = result as Array;     for (var pg:int = 0; pg < pRslts.length; pg++)     {      var pGeom:Geometry = pRslts[pg];      token[pg].geometry = pGeom;      token[pg].addEventListener(MouseEvent.CLICK, mClick);     }          graphicsLayer.graphicProvider = token;    }        private function mClick(event:MouseEvent):void    {     map.infoWindow.showInAutomationHierarchy;    }         ]]>  </fx:Script>
Can someone tell me how to do this the right way? Please
RobertScheitlin__GISP
Ann,
   There are some other issues I see in your code:
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"                 xmlns:s="library://ns.adobe.com/flex/spark"                xmlns:esri="http://www.esri.com/2008/ags"                xmlns:mx="library://ns.adobe.com/flex/mx"                minWidth="955" minHeight="600"                creationComplete="init()">     <fx:Script>         <![CDATA[             import com.esri.ags.Graphic;             import com.esri.ags.SpatialReference;             import com.esri.ags.events.GeometryServiceEvent;             import com.esri.ags.geometry.Geometry;             import com.esri.ags.geometry.MapPoint;                          import mx.collections.ArrayCollection;             import mx.controls.Alert;             import mx.rpc.AsyncResponder;             import mx.rpc.events.FaultEvent;             import mx.rpc.events.ResultEvent;                          import spark.components.TextArea;                          private function init():void             {                 pointsXML.send();             }                          protected function pointsXML_resultHandler(event:ResultEvent):void             {                 var gArr:Array = [];                 var myGraphics:Array = [];                 var x:XML = XML(event.result);                 var pntList:XMLList = x..entry;                 for (var i:int = 0; i < pntList.length(); i++){                     var latlong:Array = pntList.point.split(" ");                     var attrib:Object = pntList.name;                                          var myPoint:Geometry = new MapPoint(latlong[1], latlong[0], new SpatialReference(4326));                                          var coordGraphic:Graphic = new Graphic(myPoint,null,attrib);                                          gArr.push(myPoint);                     myGraphics.push(coordGraphic);                 }                 var outSR:SpatialReference = new SpatialReference(3857);                 geometryService.project(gArr, outSR, new AsyncResponder(projectCompleteHandler, null, myGraphics));                    }                          protected function projectFault(event:mx.rpc.events.FaultEvent):void             {                 Alert.show(event.fault.faultString);             }                          protected function projectCompleteHandler(result:Object, token:Object):void             {                 var pRslts:Array = result as Array;                 for (var pg:int = 0; pg < pRslts.length; pg++){                     var pGeom:Geometry = pRslts[pg];                     token[pg].geometry = pGeom;                     token[pg].addEventListener(MouseEvent.CLICK, mClick);                 }                 graphicsLayer.graphicProvider = token;             }                          protected function mClick(event:MouseEvent):void             {                 var gra:Graphic= event.target as Graphic;                 var textArea:TextArea = new TextArea();                 textArea.height = 50;                 textArea.width = 100;                 textArea.text = gra.attributes[0].toString();                 map.infoWindow.content = textArea;                 map.infoWindow.show(gra.geometry as MapPoint);             }                          protected function pointsXML_faultHandler(event:FaultEvent):void             {                 Alert.show(event.fault.message);             }                      ]]>     </fx:Script>     <fx:Declarations>         <s:HTTPService id="pointsXML"                        url="xml/properties.xml" result="pointsXML_resultHandler(event)" resultFormat="xml" fault="pointsXML_faultHandler(event)"/>         <esri:GeometryService id="geometryService"                                url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/>     </fx:Declarations>          <!--<s:navigationContent>         <s:Button width="80" height="70" click="navigator.popView()" icon="assets/backbutton.png"/>     </s:navigationContent>-->          <esri:Map id="map">         <esri:extent>             <esri:Extent xmin="-467799" ymin="5253018" xmax="2171419" ymax="6627661"/>         </esri:extent>         <esri:ArcGISTiledMapServiceLayer url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>         <esri:GraphicsLayer id="graphicsLayer">             <esri:symbol>                 <esri:SimpleMarkerSymbol alpha="0.9"                                          color="0xFFFF00"                                          size="12"                                          style="square">                     <esri:SimpleLineSymbol color="0xDD0000" width="2" alpha="1" style="solid"/>                 </esri:SimpleMarkerSymbol>             </esri:symbol>         </esri:GraphicsLayer>     </esri:Map> </s:Application>
Ann,
   See the Infowindow documentation here:
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/components/supportClasses/InfoWindow.html
The show function is what you need and all you supply is the map point you want to display the point at.
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
Ann,
sherlytobias
Its working very well now. Thank you so much!!! You helped me big time.
