getting Bing aerial imagery date
5689
06-18-2010 10:05 AM
DavidRaybuck
Is it possible to programmatically obtain the Bing imagery date or year for VETiledLayers?
RichardDaniels
MVP Regular Contributor
Yes there is, you need to use the Bing Maps API to obtain this information using the map class with the VEMap.GetImageryMetadata (see http://msdn.microsoft.com/en-us/library/cc966714.aspx )method. Check out http://msdn.microsoft.com/en-us/library/bb412551(v=MSDN.10).aspx for information about using the Bing API.
Here is the method call, where map was set with map = new VEMap('myMap').
         // Get imagery meta data of the current map
         function GetMetadata()
            map.GetImageryMetadata(MetadataCallback, null);
         function MetadataCallback(metaData)
            alert("Imagery date range: " + metaData.DateRangeStart + " - " + metaData.DateRangeEnd);
Rich
DavidRaybuck
Thanks danielri.  I know this is possible with Bing's javascript API, but I was wondering if it is possible within the ArcGIS API for Flex.
