How can I create a hyperlink tool in my flex map?
2780
06-18-2010 08:45 AM
JoshCalhoun
Hi everyone,
I am new to Flex and I wanted to add a hyperlink tool to my app. I want my users to click on a sewer line  feature class and have a .pdf file open up showing the drawing of that line. The FC has a hyperlink field.  I have one in the .net version. Does the flex API have such a tool. Or is there a way to format the identify tool to bring up the clickable link to the .pdf file?
I am using my version of the sample map viewer. Any help you can give me will be greatly appreciated.
thanks
Josh Calhoun
City of Chattanooga
SandeepTalasila
Josh,
To add the hyperlink functionality in the flex application, you need to modify your identify widget. Here is a link that might help http://forums.esri.com/Thread.asp?c=158&f=2421&t=295783
RichardDaniels
MVP Regular Contributor
You could put the URL to the PDF in the attribute table that is returned by the identify tool. If formatted correctly it will be displayed as a hyperlink in the pop up result window.
http://arcscripts.esri.com/details.asp?dbid=15939
