Get Error from Query
1825
6
11-02-2011 06:32 PM
sidneykelvin
Dear All,
I am writing a pretty simple Query but got error message and cannot figure out why.
private function setQueryDistrict(district:String):void
var query_District:Query = new Query();
if (district == "All District") district = "";
query_District.where = "DIST_ENAME like '%" + district.toLocaleUpperCase() + "%'";
query_District.returnGeometry = true;
query_District.outFields = ["DIST_ENAME,OBJECTID"];
queryTask_DistBound.execute(query_District, new AsyncResponder(onQueryResult, onQueryFault));
function onQueryResult(featureSet:FeatureSet, token:Object = null):void
  //zoomToSelected(featureSet.attributes[0].OBJECTID,false);
function onQueryFault(info:Object, token:Object = null):void
  Alert.show(info.toString());
Error message code receive on the line 'Alert.show(info.toString());'
Error #2032: 串流�?�誤�?? URL: http://cedd6288/ArcGIS/rest/services/LIC/MapServer/82/query?where=DIST%5FENAME%20like%20%27%25ISLAND...
Please note that it work normally in the page "ArcGIS Service Directory"
Thanks in advance for any help
RobertScheitlin__GISP
Sydney,
   Try changing this:
query_District.outFields = ["DIST_ENAME","OBJECTID"];
sidneykelvin
Error Still Exist.
Is there anything related to spatialRelationship? as there is something strange with the error message :
Error #2032: 串æµ�é?¯èª¤ã??...//cedd6288/ArcGIS/rest/services/LIC/MapServer/82/query?where=DIST%5FENAME%20like%20%27%25ISLANDS%25%27&outFields=DIST%5FENAME%2COBJECTID&returnGeometry=false&spatialRel=esriSpatialRelIntersects&f=amf
Thanks for your help !!!
IvanBespalov
Error #2032 is StreamError.
I tried to get a similar error and i got id:
1 - if service URL is wrong
Fault details: Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032: Stream Error. URL: http://  ivanbespalov.argisonline.com/ArcGIS/rest/services...
2 - if service URL is OK, but not accessible or not available at the moment
3 - may be something wrong with your crossdomain.xml (read adobe forums)
Note: if URL is OK, but some of query params WRONG you got not Error #2032: StreamError - you got responce from ArcGIS server with fault message = "Unable to complete Query operation.".
Sidney,
   If you are using ArcGIS Server 9.3.1 or lower than you also would want to set queryTask_DistBound.useAMF = false;
sidneykelvin
I set queryTask_DistBound.useAMF = false and it WORKS .
Thanks you very much.
I wonder if this could still work in ArcGIS server 10.
Regards
Sidney
Sidney,
   Yes having useAMF set to false will working on a ArcGIS 10 server as well.
