Adding Shape file data in ArcGIS viewer for flex 2.2 HELP,
1836
01-31-2011 06:28 AM
AndrewCummings
Already downloaded http://www.arcgis.com/home/item.html?id=bc6a88cf51364d9ea767347954363d7d
This is what I'm looking at
<!-- UI elements -->
<widget left="10" top="50" config="widgets/Navigation/NavigationWidget.xml" url="widgets/Navigation/NavigationWidget.swf"/>
<widget right="-2" bottom="-2" config="widgets/OverviewMap/OverviewMapWidget.xml" url="widgets/OverviewMap/OverviewMapWidget.swf"/>
<widget right="20" top="55" config="widgets/MapSwitcher/MapSwitcherWidget.xml" url="widgets/MapSwitcher/MapSwitcherWidget.swf"/>
<widget left="0" top="0" config="widgets/HeaderController/HeaderControllerWidget.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/>
<map initialextent="-10083000 2559000 -10879000 5558000" top="40">
<basemaps>
<layer label="Streets" type="tiled" visible="true" alpha="1"
url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
<layer label="Aerial" type="tiled" visible="false" alpha="1"
url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/>
<layer label="Topo" type="tiled" visible="false" alpha="1"
url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
</basemaps>
<operationallayers>
<layer label="Boundaries and Places" type="tiled" visible="false"
url="http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places_Alternate/..."/>
<layer label="Fires" type="feature" visible="false" alpha="1"
info="widgets/InfoTemplates/SimpleInfoWinWidget.swf"
infoconfig="widgets/InfoTemplates/IWT_Fires.xml"
url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0"/>
</operationallayers>
</map>
<!-- widgets organized into widget containers that manage close/open etc -->
<!-- supported layout property options: horizontal(default)|float|vertical|fix-->
<widgetcontainer layout="float">
<widget label="Bookmarks" left="430" top="90"
icon="assets/images/i_bookmark.png"
config="widgets/Bookmark/BookmarkWidget.xml"
url="widgets/Bookmark/BookmarkWidget.swf"/>
<widget label="Find an address" left="100" top="90"
icon="assets/images/i_target.png"
config="widgets/Locate/LocateWidget_US.xml"
url="widgets/Locate/LocateWidget.swf"/>
<widget label="Search" left="80" top="280"
icon="assets/images/i_search.png"
config="widgets/Search/SearchWidget_Louisville.xml"
url="widgets/Search/SearchWidget.swf"/>
<widget label="Draw and Measure" left="60" top="400"
icon="assets/images/i_draw2.png"
config="widgets/Draw/DrawWidget.xml"
url="widgets/Draw/DrawWidget.swf"/>
<widget label="Print" left="390" top="400"
icon="assets/images/i_print.png"
config="widgets/Print/PrintWidget.xml"
url="widgets/Print/PrintWidget.swf"/>
<widget label="Load Shape Files" x="400" y="60"
icon="widgets/ShapeFiles/images/shapefiles.png"
config="widgets/ShapeFiles/ShapeFiles.xml"
url="widgets/ShapeFiles/ShapeFiles.swf"/>
<widget label="My first widget"
icon="assets/images/i_widget.png"
config="widgets/Samples/HelloWorld/HelloWorldWidget.xml"
url="widgets/Samples/HelloWorld/HelloWorldWidget.swf"/>
</widgetcontainer>
</configuration>
And its giving me " Error #2036 "
What can I do?
TyroneLigon
Did you try using "top" and "left" attributes instead of "x" and "y"? I'm not using the SFV, but those attributes jumped out at me.
CoreyLunsford
I'm not the OP but I'm interested in this topic. I did everything he did and it is not displaying for me either. I changed the attributes to "Top" and "Left" (I copied the values from another widget that I know works) and it is not being displayed for me either. Is there an easier way to load shapefiles into flex besides this?
