Geometry service intersect through the Flex API
2992
01-09-2014 12:41 AM
Ganael_Jatteau
Hello,
I'm using the API agslib-3.0-2012-06-06 and I'm using the function GeometryService.intersect()
I noticed that this version of the API generates a request with the parameter SR=0 (instead of passing the spatial reference of the geometry)
With Arcgis 10.0 it work fine. Example:
http://sampleserver3.arcgisonline.com/arcgis/rest/services/Geometry/GeometryServer/intersect?geometr...
But with Arcgis 10.1, it throughs an error:
Invalid or missing input parameters.
the input is not a geographic or projected coordinate system
Is there a way to force the projection within the SDK? Does this issue has been fixed in newer versions?
Thanks in advance.
RobertScheitlin__GISP
Ganael,
   It was fixed in the API. I am not sure which version past 3.0 it was fixed in though.
Ganael_Jatteau
Hi Robert
Thanks for your answer.
