Geocode Server Problem
784
06-16-2010 07:59 AM
weeyeo
Hello,
I am using 'Geode an address' sample from resources website with my own geocode server services for a test but I got some ActionScript error messages after click on"Find Adress" button.  On my own services, I only have 'Street' for address Fields.  Can someone let me know why I got these messages?
Here are ActionScript error:
TypeError: Error #1010: A term is undefined and has no properties.
at testing/private:doFind/onResult()
at mx.rpc::AsyncResponder/result()
at com.esri.ags.tasks::Locator/handleAddressCandidates()
at Function/http://adobe.com/AS3/2006/builtin::call()
at com.esri.ags.tasks::BaseTask/handleResult()
at <anonymous>()
at mx.rpc::Responder/result()
at mx.rpc::AsyncToken/http://www.adobe.com/2006/flex/mx/internal::applyResult()
at mx.rpc.events::ResultEvent/http://www.adobe.com/2006/flex/mx/internal::callTokenResponders()
at HTTPOperation/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent()
at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::resultHandler()
at mx.rpc::AsyncRequest/acknowledge()
at DirectHTTPMessageResponder/completeHandler()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at flash.net::URLLoader/onComplete()
Here is the testing.mxml file
<?xml version="1.0" encoding="utf-8"?>
<mx:Application
    xmlns:mx="http://www.adobe.com/2006/mxml"
    xmlns:esri="http://www.esri.com/2008/ags"
    pageTitle="Locator task"
    layout="absolute">
    Problem:
        How to find the address (aka geocoding) for a certain address?
    Solution:
        Use the addressToLocations() method on the Locator.
    This sample takes a user-provided address and sends it to the
    server for geocoding.  When the response comes back, the OnResult()
    function creates a graphic for the result and then sets the scale
    appropriately based on if the match was a "street", "city" etc match.
    <mx:Script>
        <![CDATA[
            import com.esri.ags.Graphic;
            import com.esri.ags.tasks.AddressCandidate;
            import mx.controls.Alert;
            import mx.rpc.AsyncResponder;
            private function doFind():void
                var myAddress:Object = {
                 Street: address.text
                // Use outFields to get back extra information
                // The exact fields available depends on the specific Locator used.
                var myOutFields:Array = ["Loc_name"];
                locateTask.addressToLocations(myAddress, myOutFields, new AsyncResponder(onResult, onFault));
                function onResult(candidates:Array, token:Object = null):void
                    if (candidates.length > 0)
                        var addressCandidate:AddressCandidate = candidates[0];
                        var myGraphic:Graphic = new Graphic();
                        myGraphic.geometry = addressCandidate.location;
                        myGraphic.symbol = mySymbol;
                        myGraphic.toolTip = addressCandidate.address.toString();
                        myGraphic.id = "graphic";
                        myGraphicsLayer.add(myGraphic);
                        myMap.centerAt(addressCandidate.location);
                        // Zoom to an appropriate level
                        // Note: your tile levels and LOC_NAME might differ...
                        if (addressCandidate.attributes.Loc_name.search("RoofTop") > 0)
                            myMap.scale = 10000;
                        else if (addressCandidate.attributes.Loc_name.search("Address") > 0)
                        else if (addressCandidate.attributes.Loc_name.search("Street") > 0)
                            myMap.scale = 15000;
                        else if (addressCandidate.attributes.Loc_name.search("Zipcode") > 0)
                            myMap.scale = 40000;
                        else if (addressCandidate.attributes.Loc_name.search("City") > 0)
                            myMap.scale = 150000;
                        else
                            myMap.scale = 500000;
                        myInfo.htmlText = "<b>Found:</b><br/>" + addressCandidate.address.toString();  // formated address
                    else
                        myInfo.htmlText = "<b><font color='#FF0000'>Found nothing :(</b></font>";
                        Alert.show("Sorry, couldn't find a location for this address"
                            + "\nAddress: " + address.text);
                function onFault(info:Object, token:Object = null):void
                    myInfo.htmlText = "<b>Failure</b>" + info.toString();
                    Alert.show("Failure: \n" + info.toString());
    </mx:Script>
            <esri:Locator
            id="locateTask"
            url="http://gis:8399/arcgis/rest/services/test/strLineAddrLoc/GeocodeServer"/>
        <esri:SimpleMarkerSymbol id="mySymbol" size="19" style="circle" color="0xFF0000" alpha="0.5">
            <esri:SimpleLineSymbol width="2"/>
        </esri:SimpleMarkerSymbol>
    <!-- End Declarations -->
<esri:Map id="myMap">
<esri:extent>
  <esri:Extent xmin="2752949.93511196" ymin="1066104.20883429" xmax="2876025.15404258" ymax="1203974.71599628">
   <esri:SpatialReference wkid="102698"/>
  </esri:Extent>
</esri:extent>
         <esri:ArcGISDynamicMapServiceLayer
         url="http://gis:8399/arcgis/rest/services/test/MapServer"/>
      <esri:GraphicsLayer id="myGraphicsLayer"/>
</esri:Map>
    <mx:Panel title="Find an address" top="5" horizontalCenter="0">
        <mx:Form>
            <mx:FormItem label="Street">
                <mx:TextInput width="100%" id="address" text="4102 NE 82nd St"/>
            </mx:FormItem>
            <mx:FormItem>
                <mx:Button label="Find Address" click="doFind()"/>
            </mx:FormItem>
        </mx:Form>
        <mx:Text id="myInfo" width="100%" color="0x00FF00" textAlign="center" />
    </mx:Panel>
</mx:Application>
Thank you very much.
wyeo
RobertScheitlin__GISP
wyeo,
   your locator service probably does not have a Loc_name field that it returns so you are getting the error.
weeyeo
wyeo,
Robert,
Thank you for pointing it out.
Wyeo
