Problem with Simple Flex Viewer
633
06-17-2010 12:03 PM
francescodi_vito
Hi my name is Francesco. I have one question and one problem.
After the download of simple flex viwer by to web site arcgis, i loaded the simple flex viwer in my flex builder. The index file on my browser it's ok, but when i insert the URL of my mapservice ( that i published ) in the config.xml, when i run the application my mapservice on the flexviwer in not visible ( i imposted also the initial and full extent ) why i have this problem? There is a solution?
Second question! If i build a new application whitout simple flex viwer, and after i want insert the box that are in the flex viwer, what is the procedure?...in the API library there aren't the withget of this application
I wait a answer
thanks
