Flexviewer search by text by default
2248
10
11-16-2010 09:55 AM
ChrisOwen
How do you get the search widget to default to the text search rather than the graphic search.
This seems so trivial, but I have not found the solution.
Chris
RobertScheitlin__GISP
Chris,
  Are you talking about SFV 1.3 or Flexviewer 2.1
If FlexViewer 2.1 than add
currentState="textInput"
to the viewer:BaseWidget element.
If SFV 1.3 than add
selectedIndex="1"
to the mx:ViewStack
ChrisOwen
Robert,
I am using FV 2.1 - where in the BaseWidget element is the code supposed to be inserted?
Chris
Chris,
   it is just an attribute of the BaseWidget element so it does not matter where you put it inside the element.
ChrisOwen
Still not working for me....
So anywhere inside BaseWidget.as?
Chris,
No you need to add it as a attribute of the viewer:BaseWidget element in your SearchWidget.mxml
Like this:
<viewer:BaseWidget xmlns:esri   ="http://www.esri.com/2008/ags"
       xmlns:fx    ="http://ns.adobe.com/mxml/2009"
       xmlns:s    ="library://ns.adobe.com/flex/spark"
       xmlns:mx    ="library://ns.adobe.com/flex/mx"
       xmlns:mxeffects      ="com.adobe.ac.mxeffects.*"
       xmlns:viewer         ="com.esri.viewer.*"
       xmlns:Search        ="widgets.eSearch.*"
       x="600" y="300"
       widgetConfigLoaded="init()">
ChrisOwen
Robert,
Looks like I have version 1.02 - sorry!
I tried the
selectedIndex="1"
in the mx:ViewStack, but it didn't work.
I haven't worked in Flex for awhile, I am behind the times.
Chris,
   This definitely works for me.
<mx:ViewStack id="viewStack" width="100%" height="100%" creationPolicy="all" paddingTop="4" selectedIndex="1">
ChrisOwen
Robert,
I have attached my code for you to view - do you see any issue of why the darn search by text won't start on default?
Chris
Chris,
   Based on your code change
selectedIndex="20"
to
selectedIndex="0"
