Flex 2.4 Title Bar and Widgets have no color
873
08-29-2011 05:47 AM
BarryHill1
The Flex Application title bar and widgets are Gray Scale, not the blue in the previews.  Does this have something to do with my computer settings? Dell Optiplex 790 pc running Windows 7 Professional on a 64 bit OS. Any suggestions for this newbie?
RobertScheitlin__GISP
Barry,
   The default style of the viewer is black to change this refer to the documentation here:
http://help.arcgis.com/en/webapps/flexviewer/help/01m3/01m30000000s000000.htm
I use Blue on all my custom widget previews and set it using this method.
Also if you want to discuss or ask a question about widgets or anything Flex Viewer than you should post to the Flex Viewer forum and not here the Flex API forum:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
BarryHill1
Thank you Robert, and I will post all future threads to the Viewer Forum. Thank you for taking the time and hopefully you won't see my name very often.
