Flex 1.3 Toggle Graphic on and off
1838
02-16-2011 07:31 AM
BryanWestphal
Im trying to toggle a graphic on and off based off a users click event.  I query the feature, but cannot find a way to check if the graphic already exists in the graphics layer to remove it, thus the graphics keep overlapping themselves.  Is there a way to check the graphics layer to see if that graphic already exists?
Thanks in advance.
Bryan
RobertScheitlin__GISP
Bryan,
   Just loop though the graphics in the graphicsProveder to see if one has the identical geometry.
BryanWestphal
Robert,
Thanks for the response.
Here is what i have in a testing environment, but it seems that im not getting the geometry test to come back true.
private function onQueryExecuteComplete(event:QueryEvent):void
var oneGraphic:Graphic = event.target as Graphic;
var fset:FeatureSet = event.featureSet;
for each (var graphic:Graphic in fset.features)
  for each(var graLyrGraphic:Graphic in myGraphicsLayer.graphicProvider)
   myInfo.text = "started loop";
   if (graLyrGraphic.geometry == graphic.geometry)
    myInfo.text = "found similar geometry";
                                //THIS IS WHERE I WOULD REMOVE THE GRAPHIC
    return;
                graphic.symbol = new SimpleFillSymbol('solid',0xcc0000,.7)
  myGraphicsLayer.add(graphic);
  dist1PopTotal+=graphic.attributes.POPULATION;
return;
Bryan,
   Try this instead.
      if (graLyrGraphic.attributes === graphic.attributes)
       return;
    return;
BryanWestphal
Figured it out.  here is the code that works for me.  thanks again for your help robert
   if(district1tool == true)
    for each(var graphic:Graphic in fset.features)
      graphic.name = graphic.attributes.PRECINCT
      if(graLyrGraphic.name == graphic.name)
       for (var i:int = myGraphicsLayer.numGraphics - 1; i >= 0; i--)
        if(myGraphicsLayer.graphicProvider.name == graphic.name)
         if (district1tool == true)
          dist1PopTotal -= myGraphicsLayer.graphicProvider.attributes.POPULATION
          myGraphicsLayer.remove(myGraphicsLayer.graphicProvider);
          return;
       return;
    return;
