calling webservices from action script - order of events?
1616
02-16-2011 09:53 AM
grahamcooke
I have a problem that I cannot seem to easily solve with a call out to a webservice. i have created an actionscript class to act as a webservice handler. In this class i set up my webservice and the corresponding events and declare a property getter to return the arraycollection that holds the resulting table from the .net webservice.
this is my class:
public function getWebServiceData(_selectedMortarSize:int, _numStepMaxCharge:int, _piIllum:String, _piUSAmmo:String):void
                  selectedMortarSize = _selectedMortarSize;
                  numStepMaxCharge = _numStepMaxCharge;
                  piIllum = _piIllum;
                  piUSAmmo = _piUSAmmo;
                  ws = new WebService();
                  ws.wsdl = "http://lmgis02/cawdapt_ws/cawdapt_dotnet_ws.asmx?wsdl"
                  ws.getMortarChargeData.resultFormat = "object";
                  ws.getMortarChargeData.addEventListener("result", myResultHandler);                       ws.getMortarChargeData.addEventListener("fault", myFaultHandler);
                  //need to set up a load result handler to catch when the webservice is loaded. From here we will
                  //pass the parameters and then the results will be returned in the result handler code.
                  ws.addEventListener(LoadEvent.LOAD, loadHandler);
                  //call webservice, result event handler will populate the arraycollection which will then be passed to the action script.
                 ws.loadWSDL();
protected function loadHandler(event:LoadEvent):void
                  // send() takes the service parameters
                 ws.getMortarChargeData.send(selectedMortarSize, numStepMaxCharge, piIllum, piUSAmmo);
            protected function myResultHandler(event:ResultEvent):void
                 myMortarChargeData = new ArrayCollection();
                  myMortarChargeData = event.result.Tables.mortarChargeData.Rows;
            protected function myFaultHandler(event:FaultEvent):void
                  Alert.show(event.toString());
i then have a procedure in my widget code that instantiates this class, and (hopefully!) gets the arraycollection and then passes that array collection into another routine that plots a polygon
//Code that calls the webservice handler:
var myWS:MortarsWS = new MortarsWS
myWS.getWebServiceData(selectedMortarSize, numStepMaxCharge.value, piIllum, piUSAmmo);
mortarChargeData = myWS.MortarChargeData;
//code that uses the mortarChargeData
//instantiate FP class with standard trace variables setup
x = new myClass(mortarChargeData, [othervariables])
This is all initiated on a user button click, the parameters i am passing to the webservice are set up by the users interaction with the controls on the widget. The problem I am having is that the loadresult call in the webservice handler is not firing until AFTER the code has dropped into myClass and attempted to use items from the mortarChargeData arraycollection.
Why are the webservice loadhandler, the resultant send operation and the result event handler all firing after I intended them to? Can anyone see what I am doing wrong?
Hope someone can help!
ReneRubalcava
Esri Frequent Contributor
// this happens before data is returned
The problem you are having is you are trying to get the results of your service call from your myWS object before myWS has had a chance to get the process the results.
You could have your myWS object dispatch an Event.COMPLETE when it's done, so it would look like
// have your myWS extend EventDispatcher
    dispatchEvent(new Event(Event.COMPLETE));
Then listen for it
// just an example, you should probably use a named function
myWS.addEventListener(Event.Complete, function(e:Event):void { mortarChargeData = myWS.MortarChargeData; });
grahamcooke
perfect! thankyou 🙂
