FeatureLayer not showing in EditWidget
3194
14
12-20-2010 05:45 AM
RichardHolloway
I have my Feature service set up.  I have given edit permissions to the service.  The mapservice is setup as a operational layer.  Do I also add another layer with the featureservice or do I add it as a layer in the Edit Widget?  Not sure what the step by step instructions are on this part.
RichardHolloway
Has anyone even done one of these?????
AniketWani
You need to add feature service not map service in operational layer section, to make it work with edit widget.
Refer to Edit widget sample http://help.arcgis.com/en/webapps/flexviewer/live/?config=config-edit.xml and config file
http://help.arcgis.com/en/webapps/flexviewer/live/config-edit.xml
            <layer label="HomeLand Security Incident Points" type="feature" visible="true"
                   info="widgets/InfoTemplates/SimpleInfoWinWidget.swf"
                   infoconfig="widgets/InfoTemplates/IWT_IncidentPoints.xml"
                   url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/FeatureServer/0"/>
RichardHolloway
Yep,
Have that already.
<layer label="editfeature" type="feature" visible="false" alpha="1"
                  url="http://myserver/arcgis/rest/services/featureSNG/FeatureServer/0"/>
RichardHolloway
Been trying to figure out whats wrong all day and still no go.  Any ideas?
AniketWani
Try to capture the requests for errors using firebug / fiddler when you open the edit widget.
Also if can post the config files, config.xml as well as editWidget.xml then that will helpful to debug.
RichardHolloway
I will try that.  In the mean time here is my config.xml and editwidget.xml files in the .zip.  I appreciate any help you can give me as I am at a standstill.
RichardHolloway
I am not capturing anything in FireBug.  Is there anyone out there????
RichardHolloway
You do know if there is no template showing I do not get anything in firebug right?  Thats my issue is no templates are showing.
AniketWani
You might want to double check the feature service. Where it is editable or not?
