feature layer zoom in
2284
9
09-15-2010 10:35 AM
abukhan
how to zoom in the results from the feature layer query?
ReneRubalcava
Esri Frequent Contributor
A FeatureLayer is a subclass of a GraphcisLayer, so you can use GraphicUtil.getGraphicsExtent to do it, after you have done a selection on the FeatureLayer.
var ac:ArrayCollection = featureLayer.graphicProvider as ArrayCollection;
map.extent = GraphicUtil.getGraphicsExtent(ac.toArray());
abukhan
Which event in feature layer that fires at the end of query results? I mean in which event (in feature layer) fires when all the features are returned to the client from the server?
ReneRubalcava
Looking at the docs
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/FeatureLayer.html
The returned event is QUERY_FEATURES_COMPLETE.
com.esri.ags.events.FeatureLayerEvent.QUERY_FEATURES_COMPLETE
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/FeatureLayer.html#event:queryFeatur...
I have not used queryFeatures in my apps yet, so I'm not sure if results will be displayed as graphics on screen, but the QUERY_FEATURES_COMPLETE event returns a FeatureSet.
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/events/FeatureLayerEvent.html
DasaPaddock
QUERY_FEATURES_COMPLETE is for when you call the queryFeatures() method:
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/FeatureLayer.html#queryFeatures()
Listen for updateEnd if you want to know when the FeatureLayer has finished loading new features and made them available in it's graphicProvider.
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/layers/Layer.html#event:updateEnd
abukhan
One issue with updateEnd that it even happens when panning or zooming (the feature layer gets updates with zooming and panning).
Is there any event that I can use when feature layer first time gets queried using definitionexpression.
( i would like to zoomin to the return features at the initial time)...
So what is happening now If I put my code(for zooming in the return features) in the updateEnd event, any time user pans , it comes to the previous zooming....
abukhan
One way I solved this issue using an boolean variable that I set initially and the updateend checks for this boolean variable (only does zooming in the first time)..
abukhan
About the utility function :
GraphicUtil.getGeometries
It extracts array of geometries from array of graphics
Is there any way to get features that are outside and touching these geometries?
I mean if there are 20 geometries (of graphics), I want to get features that are outside the 20 geometries touching them...
DasaPaddock
Another option may be to remove the updateEnd listener.
DasaPaddock
You may be able to do this using a geoprocessing task:
http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/tasks/Geoprocessor.html
