Lost some files in compiling
1399
09-17-2010 07:53 AM
ShaningYu
Honored Contributor
I just changed another CPU and then I re-compiled my Flewviewer project (based on ESRI's V1.3 w/ customization).  However, after compiling, some images are not loaded into the \bin-debug\...\images\icons\ folder.  Does anyone know how to fix this problem?  Thanks.
RobertScheitlin__GISP
Shaning,
   Sometimes that just happens and you have to manually copy the files from your src folder into your bin-debug.
ShaningYu
Honored Contributor
Robert:
Thank to you for your many kindly responses to my Q's.  I am very impressed your superior skills in this field.  The problem I reported this time happens always (not occassionally reported before).  It give me some headache.
Have a nice weekend.
Shaning
ShaningYu
Honored Contributor
From http://support.microsoft.com/kb/257046, I guess that the problem is due to the reason stated in that post:
The folder that you are attempting to copy has a path that exceeds 250 characters. Or, the folder that you are attempting to copy contains subfolders and the full path to one or more of the subfolders exceeds 250 characters.
In that post, it also mentions that:
Microsoft has confirmed that this is a problem in the Microsoft products that are listed at the beginning of this article.
ShaningYu
Honored Contributor
You recommended approach:  manually copy the files from your src folder into your bin-debug.
The files missed are several images.  I used your approach.  It works for some images that display on the map, but for some of images that do not display on map.  Stranger.
