Editor layout
2801
07-14-2012 12:35 PM
AmandaHutsel
Is there a way to change the layout of the templates?  There are two feature layers Historic and Grant with only 1 editable feature each.  They look like this now
[ATTACH=CONFIG]16104[/ATTACH]
but I would like it to look like this.
[ATTACH=CONFIG]16105[/ATTACH]
BjornSvensson
Esri Alum
Yes, using skins.  You can change the skin of the TemplatePicker from the default "TemplatePickerSkin" to either the "simple" TemplatePickerSimpleSkin provided or edit the skin to you liking.  In your case, the provided "simple" skin might be pretty close to what you want.
<fx:Style>         @namespace esri "http://www.esri.com/2008/ags";                  esri|TemplatePicker         {             skinClass: ClassReference("com.esri.ags.skins.TemplatePickerSimpleSkin");         } </fx:Style>
You can read more about skinning on http://resources.arcgis.com/en/help/flex-api/concepts/index.html#/Styling_and_skinning_overview/017p...
The skins are listed in the API Reference
http://resources.arcgis.com/en/help/flex-api/apiref/index.html?com/esri/ags/skins/package-detail.htm...
and are available in the "API Library download" (with the swc)
See for example
TemplatePickerSimpleSkin - Alternative skin class for the TemplatePicker component which does not group feature templates by feature layers.
BjornSvensson
Esri Alum
See for example
