Editor info-window behavior in Mobile App
2064
07-23-2012 04:42 AM
AaronNash
Not sure if anyone has attempted to enable editing in a flex mobile application, but when you add a feature or edit attributes of a feature the info window it creates is significantly wider than in a web application. It goes off the screen, I am trying to set this up to work on a tablet. Please see the attached screen shot, any input would be appreciated
thanks,
  Aaron
HoomanMohammadpour
Hi There,
Would you be able to share your information about how were you able to add the Editor to your mobile? I can't even get the Editor in my view, apparently it's relying on certain mx controls and does not compile. Would you be able to share your code?
Hooman
MarkDeaton
Esri Alum
I apologize for replying to a really old thread, but I'm having the same problem: the attribute editor panel stretches several screens to the left and to the right when it opens after a feature gets created.
I also was unable to use the editor component in a mobile project at first; then I added the mx.swc and sparkskins.swc libraries to my project and it compiled and ran.
MarkDeaton
Esri Alum
I can work around this partially like this:
application1_initializeHandler(event:FlexEvent):void {
[INDENT]editorComponent.attributeInspector.width = 300;[/INDENT]
This narrows the inspector panel to a usable size, but the edit field border is cut off on the right side.
AaronNash1
i never found a solution for this, moved on to something else. Sorry I can't help
