Custom com.esri.ags.symbols.Symbol
4357
10
03-16-2011 09:26 AM
Ganael_Jatteau
Hello!
I'm trying to write a custom symbol that extends com.esri.ags.symbols.Symbol to display my own UIComponent on the map.
I did some tests by overriding the method createSwatch but it doesn't get called...
Anyone has managed to do that ? Is there any example somewhere ?
Thanks a lot in advance
RobertScheitlin__GISP
Ganael,
   You need to be overriding the draw method. The createswatch method is only used in custom development like creating a legend.
Here is some code from Mansour's Blog. http://thunderheadxpler.blogspot.com/
package com.esri.overlay
    import com.esri.ags.Map;
    import com.esri.ags.geometry.Geometry;
    import com.esri.ags.geometry.MapPoint;
    import com.esri.ags.symbol.Symbol;
    import flash.display.Bitmap;
    import flash.display.Loader;
    import flash.display.LoaderInfo;
    import flash.display.Sprite;
    import flash.events.Event;
    import flash.events.IOErrorEvent;
    import flash.geom.Matrix;
    import flash.net.URLRequest;
    import flash.system.Capabilities;
    import flash.system.LoaderContext;
    import mx.controls.Label;
    public class OverlaySymbol extends Symbol
        private const m_matrix:Matrix = new Matrix();
        private var m_bitmap:Bitmap;
        private var m_source:Object;
        private var m_width:Number = 0;
        private var m_height:Number = 0;
        private var m_rotation:Number = 0;
        private var m_iname:String = "";
        private var m_alpha:Number = 1;
        public function OverlaySymbol(source:String=null, width:Number=0,
            height:Number=0, rotation:Number=0, alpha:Number=1)
            m_source = source;
            m_width = width;
            m_height = height;
            m_rotation = rotation;
            m_alpha = alpha;
        [Bindable]
        public function get source():Object
            return m_source;
        public function set source(value:Object):void
            if (value != m_source)
                m_bitmap = null;
                m_source = value;
                dispatchEventChange();
        [Bindable]
        public function get rotation():Number
            return m_rotation;
        public function set rotation(value:Number):void
            if (value != m_rotation)
                m_rotation = value;
        [Bindable]
        public function get width():Number
            return m_width;
        public function set width(value:Number):void
            if (value != m_width)
                m_width = value;
        [Bindable]
        public function get height():Number
            return m_height;
        public function set height(value:Number):void
            if (value != m_height)
                m_height = value;
        [Bindable]
        public function get alpha():Number
            return m_alpha;
        public function set alpha(value:Number):void
            if (value != m_alpha)
                m_alpha = value;
        override public function clear(sprite:Sprite):void
            sprite.graphics.clear();
        override public function draw(sprite:Sprite, geometry:Geometry, attributes:Object, map:Map):void
            if (geometry is MapPoint)
                drawOverlay(sprite, MapPoint(geometry), map);
        private function drawOverlay(sprite:Sprite, mapPoint:MapPoint, map:Map):void
            if (m_bitmap == null)
                if (m_source is Class)
                    m_bitmap = new m_source();
                    drawBitmap(sprite, mapPoint, map);
                else if (m_source is String)
                    var url : String = String(m_source);
                    if( Capabilities.isDebugger == true )
                        url = url + (url.indexOf("?") > -1 ? "&debug=true" : "?debug=true");
                    const loaderContext:LoaderContext = new LoaderContext();
                    loaderContext.checkPolicyFile = true;
                    const loader:Loader = new Loader();
                    loader.contentLoaderInfo.addEventListener(Event.COMPLETE, completeHandler);
                    loader.contentLoaderInfo.addEventListener(IOErrorEvent.IO_ERROR, onLoaderError );
                    loader.load(new URLRequest(url), loaderContext);
                    function completeHandler(event:Event):void
                        const loaderInfo:LoaderInfo = event.target as LoaderInfo;
                        m_bitmap = loaderInfo.content as Bitmap;
                    function onLoaderError(evt:Event):void
                     //do nothing
            else
        private function drawBitmap(sprite:Sprite, mapPoint:MapPoint, map:Map):void
            const width2:Number = m_width / 2.0;
            const height2:Number = m_height / 2.0;
            const xmin:Number = toScreenX(map, mapPoint.x);
            const xmax:Number = toScreenX(map, mapPoint.x + m_width);
            const ymax:Number = toScreenY(map, mapPoint.y);
            const ymin:Number = toScreenY(map, mapPoint.y + m_height);
            const width:Number = xmax - xmin;
            const height:Number = ymax - ymin;
            m_matrix.a = width / m_bitmap.bitmapData.width;
            m_matrix.d = height / m_bitmap.bitmapData.height;
            m_matrix.tx = width / m_bitmap.bitmapData.width;
            m_matrix.ty = height / m_bitmap.bitmapData.height;
            sprite.x = toScreenX(map, mapPoint.x);
            sprite.y = toScreenY(map, mapPoint.y);
            sprite.rotation = m_rotation;
            sprite.alpha = m_alpha;
            sprite.graphics.beginBitmapFill(m_bitmap.bitmapData, m_matrix, false, true);
            sprite.graphics.drawRect(m_matrix.tx, m_matrix.ty, width, height);
            sprite.graphics.endFill();
            var tLabel:Label = new Label();
            tLabel.text = m_iname;
            tLabel.x = sprite.x + 10;
            tLabel.y = sprite.y + 10;
            sprite.addChild(tLabel);
Ganael_Jatteau
Thanks Robert
I will search how I can transfer the content of my UIComponent into the Sprite given by the method draw(). I'll post some code when I have the solution.
Ganael,
   Actually you would just be adding your UIComponent to the sprite. The sprite is already provided.
sprite.addChild(yourUIComponent);
Ganael_Jatteau
I tried a quick example using sprite.addChild(UIComponent) but the symbol seems empty. At least, it doesn't displays on the map...
public override function draw(sprite:Sprite, geometry:Geometry, attributes:Object, map:Map):void
     var label:Label = new Label();
     sprite.x = toScreenX(map, (geometry as MapPoint).x);
     sprite.y = toScreenY(map, (geometry as MapPoint).y);
     label.text = "dummy label";
     label.x = sprite.x;
     label.y = sprite.y;
     label.alpha = 1;
     sprite.addChild(label);
     sprite.width = 50;
     sprite.height = 20;
    else throw new Error("not a map point ");
Ganael,
   Here is a VERY simple example one that works.
package org.calhoun.county
 import com.esri.ags.symbols.Symbol;
 import flash.text.TextField;
 import flash.text.TextFieldAutoSize;
 public class MySymbol extends Symbol
  public function MySymbol()
   super();
    var m_textField:TextField;
    m_textField = new TextField();
    m_textField.name = "textField";
    m_textField.mouseEnabled = false;
    m_textField.mouseWheelEnabled = false;
    m_textField.selectable = false;
    m_textField.autoSize = TextFieldAutoSize.CENTER;
    m_textField.text = "Dummy Text";
    sprite.addChild(m_textField);
    sprite.width = 50;
    sprite.height = 20;
Ganael_Jatteau
Thanks, your example works well. So I understand it won't work to add an mx or spark component to the sprite.
Ganael,
   I am not sure on the exacts of the requirements but it seems like spark primitives are necessary.
SarahBurgin
Hi, this topic looks interesting as I'd like to add spark.primitives.Graphic (specifically spark.primitives.Ellipse) objects to a map layer... is this something that's possible to do? Thanks!
SarahBurgin
I'm making some progress. Starting from the simple example provided by rscheitlin above, I've been able to create a similar custom symbol and display it against the map using a GraphicsLayer. My draw method firstly creates a spark.primitives.Ellipse, then creates a spark.primitives.Graphic and uses addElement(ellipse) on the graphic before then invoking addChild(graphic) on the sprite.
This is somewhat successful and I've also been able to scale the custom ellipse symbols so that they maintain the correct size whenever the map is zoomed, however it seems that sprite.x and sprite.y locate the top-left corner of the Ellipse instead of the centre, so my custom symbol appears in the wrong place on the map. I haven't been able to resolve this, unfortunately.
The issue is also further complicated when I apply the necessary rotation to each Graphic. This turns out to likewise rotate the symbol around its top-left corner whereas I need the ellipses to be rotated around their centre instead.
Do any of the expects here know of ways to correct these problems please? I hope so - thanks!
