Convert miliseconds to datetime
6234
6
12-02-2014 04:27 AM
EvelynHernandez
Hello everybody,
I have a view that contains a date field and when i use the service to show the data, the service automatically return the date in miliseconds.
Is there a way to change that? Cuz the view has the field correctly and i dont know why the service changes the value.
Example: fc_evento: 1417427606000 (in arcgis srv)
It has to show 1/12/14 4:53 (in view)
Thanks
RobertScheitlin__GISP
Evelyn,
  Sorry an eGridColumn is a custom column type of my eSearch widget. So you need to just remove those references and manually set some values:
            private function getDateLbl(item:Object,column:GridColumn):String
                var dateMS:Number = Number(item[column.dataField]);
                var retVal:String = "";
                var rVal:String = item[column.dataField];
                var dateFormatStr:String;
                var cuseUTC:Boolean;
                if(rVal == null){
                    //do nothing
                }else{
                    if (!isNaN(dateMS)){
                        dateFormatStr = "MM/dd/yy L:NN";
                        retVal = msToDate(dateMS, dateFormatStr, true);
                return retVal;
<s:GridColumn id="fc_evento" dataField="fc_evento" headerText="fc_evento" labelFunction="{getDateLbl}"></s:GridColumn>
Evelyn,
  It is the standard for ArcGIS Server to return a date as UTC (in milliseconds). You will have to convert that number to a date using code like this:
dateMS: is the millisecond value that you are getting back from ArcGIS Server
dateFormat: is the string representation of the date format that you desire ("MM/dd/yy L:NN").
useUTC: adjusts for timezone offset.
value = msToDate(dateMS, dateFormat, useUTC);
            private function msToDate(ms:Number, dateFormat:String, useUTC:Boolean):String
                var date:Date = new Date(ms);
                if (date.milliseconds == 999){ // workaround for REST bug
                    date.milliseconds++;
                if (useUTC){
                    date.minutes += date.timezoneOffset;
                if (dateFormat){
                    dateFormatter.dateTimePattern = dateFormat;
                    var result:String = dateFormatter.format(date);
                    if (result){
                        return result;
                    }else{
                        return dateFormatter.errorText;
                }else{
                    return date.toLocaleString();
EvelynHernandez
the import for dateFormatter and dateFormatter.dateTimePattern i cannot find them.
I have tried import mx.formatters.DateFormatter;
Another question, i was doing a itemrenderer based on the gridcolumn but i cannot use the function to convert the value.
BTW, im making this for a widget.
Thanks
Evelyn,
So you would assign the datagrid columns labelFunction then.
dgCol.labelFunction = getDateLbl;
import spark.formatters.DateTimeFormatter;
private var dateFormatter:DateTimeFormatter = new DateTimeFormatter();
                if(rVal == null){
                    //do nothing
                }else{
                        //Fix the date format to use the Spark format
                        if(column is eGridColumn){
                            dateFormatStr = (column as eGridColumn).DateFormat;
                            cuseUTC = (column as eGridColumn).useUTC;
                        dateFormatStr = dateFormatStr.replace(/D/g, "d").replace(/Y/g, "y");
                        retVal = msToDate(dateMS, dateFormatStr, cuseUTC);
                return retVal;
EvelynHernandez
Well, i did what u said, but im still having an issue with the eGridColumn. And i cannot see that is the problem. am I doing something wrong on the widget?
The agregarItems() function get the result for the view (4 fields) (coleccion = new ArrayCollection(featureSet.attributes); and (datos.dataProvider = coleccion;). I need to convert the fc_evento field to a datetime, cuz it is milliseconds.
Grid:
<s:DataGrid id="datos" dataProvider="{coleccion}"  resizableColumns="true" sortableColumns="true" contentBackgroundAlpha="1"  width="100%" height="90%" visible="true" editable="false" bottom="1">
  <s:columns>
  <s:ArrayList>
  <s:GridColumn id="fc_evento" dataField="fc_evento" headerText="fc_evento"></s:GridColumn>
  <s:GridColumn id="gl_ip" dataField="gl_ip" headerText="gl_ip" ></s:GridColumn>
  <s:GridColumn id="gl_param_ejec" dataField="gl_param_ejec" headerText="gl_param_ejec" ></s:GridColumn>
  <s:GridColumn id="gl_mensaje" dataField="gl_mensaje" headerText="gl_mensaje" ></s:GridColumn>
  </s:ArrayList>
  </s:columns>
  </s:DataGrid>
<s:Button id="BuscarCapex" label="Buscar" click="BuscarCapex_clickHandler(event)"></s:Button>
//Functions
protected function BuscarCapex_clickHandler(event:MouseEvent):void
  // TODO Auto-generated method stub
  //IdentityManager.instance.enabled = true;
  agregarItems();
  fc_evento.labelFunction = getDateLbl;
  if(rVal == null){
  //do nothing
  }else{
  return retVal;
  if (useUTC){
  if (dateFormat){
  if (result){
  return result;
  }else{
  }else{
Idk what im doing wrong...
Thanks for ur patience
Evelyn,
                if(rVal == null){
                    //do nothing
                }else{
                return retVal;
EvelynHernandez
Works perfectly. Thanks a lot for ur help
