Convert a Polygon to Polyline for cut
6596
04-01-2013 09:25 AM
by Anonymous User
Not applicable
I'm attempting to clip polygons with another polygon using the the cut operation.  The geomtry service requires a polyline for the "cutter" and the target can be polygons.  I have a polygon that I need to convert to a polyline(paths) before I can do the clip/cut.  Does someone have the code to do this conversion.  It might be simple - but, I can't find it.  thanks
RobertScheitlin__GISP
Dan,
   Just take the Polygons.rings array and set them to the paths array of a new polyline.
Dan,
by Anonymous User
Not applicable
cutPline.paths = poly.rings;
Well, I have have my polyline, thanks - let's see if I can use it to cut some polygons.
Dan,
by Anonymous User
Not applicable
    function polygonToPolyline(polygon:Polygon):Polyline
     const polyline:Polyline = new Polyline;
     for each (var ring:Array in polygon.rings)
      polyline.addPath(ring);
     return polyline;
PriyaRam
     return polyline;
I tried with your example provided, but the cut didn't work. Did you get this working? Two polygons overlap on the top of each other in my case. Probably I'm missing a spatial reference, where should I set it.
              var arr:Array = fireAreas.selectedFeatures;
 var polyLineTemp:Polyline = polygonToPolyline( ((arr[1] as Graphic).geometry) as Polygon);
 var arr1:Array = [];
 arr1.push((arr[0] as Graphic ).geometry);
 geomService.cut( arr1,polyLineTemp, new AsyncResponder(onQueryResult, onQueryFault) );
Thanks,,
Priya
