Column Chart - The charts's icons are on top of the chart I open
2567
03-20-2013 12:35 PM
by Anonymous User
Not applicable
Original User: ionara_wilson
[ATTACH=CONFIG]22809[/ATTACH][ATTACH=CONFIG]22810[/ATTACH]I am using the pie chart example here
http://help.arcgis.com/en/webapi/flex/samples/index.html#//01nq00000040000000
to create an application with a column chart. However, in the ESRI example,  the chart that I open gets to be on top of the others, but in mine I can see the other charts's icons overlap with my chart. How can I change the code to have the chart that I open, to be on top of the other chart's icons, as the ESRI sample?  I am attaching images for comparison.  Does anybody have any idea why this is happening? Thank you!!!
Here is my snippet
 protected function myMap_initializeHandler(event:MapEvent):void    {     // Query to get the cities under the specified state     var queryTask:QueryTask = new QueryTask();     queryTask.url = "http://tfsgis-iisd01:6080/arcgis/rest/services/Economic_Impacts_Trends/TrendsServiceYearsJoined/MapServer/0";     queryTask.useAMF = false;     var expr:String = "";    /*    expr = "YEAR_DATA = '2009'" */        expr = "1 = '1'"       var query:Query = new Query();     query.outSpatialReference = myMap.spatialReference;     query.outFields = [ "*"];     query.returnGeometry = true;     query.where = expr;      queryTask.execute(query, new AsyncResponder(onResult, onFault));     // add the graphic on the map              function onResult(featureSet:FeatureSet, token:Object = null):void     {      for each (var myGraphic:Graphic in featureSet.features)      {                myGraphicsLayer.add(myGraphic);       // creating an arraycollection from the graphic attributes       var object:ArrayCollection = new ArrayCollection(        [                  { NAME: myGraphic.attributes.NAME, YEAR: "Industry Output Totals", VALUE: myGraphic.attributes.YEAR_DATA, TOTAL07: myGraphic.attributes.DirTotal_1, TOTAL09: myGraphic.attributes.DirTotal_5 },                         ]);       myGraphic.attributes = object;      }     }     function onFault(info:Object, token:Object = null):void     {      Alert.show(info.toString());     }    }
And the renderer:
<?xml version="1.0" encoding="utf-8"?> <s:VGroup xmlns:fx="http://ns.adobe.com/mxml/2009"     xmlns:s="library://ns.adobe.com/flex/spark"     xmlns:mx="library://ns.adobe.com/flex/mx"     clipAndEnableScrolling="true"     creationComplete="creationCompleteHandler()"     implements="mx.core.IDataRenderer">  <!--  This is used by the QueryResultsWithChart sample.  -->  <fx:Style>   @namespace s "library://ns.adobe.com/flex/spark";   @namespace mx "library://ns.adobe.com/flex/mx";      .InfoCloseButton {    disabledSkin: Embed(source="/assets/skins.swf", symbol="Callout_closeButtonDisabledSkin");    downSkin: Embed(source="/assets/skins.swf", symbol="Callout_closeButtonDownSkin");    overSkin: Embed(source="/assets/skins.swf", symbol="Callout_closeButtonOverSkin");    upSkin: Embed(source="/assets/skins.swf", symbol="Callout_closeButtonUpSkin");   }      .InfoExpandButton {    disabledSkin: Embed(source="/assets/skins.swf", symbol="Callout_expandButtonDisabledSkin");    downSkin: Embed(source="/assets/skins.swf", symbol="Callout_expandButtonDownSkin");    overSkin: Embed(source="/assets/skins.swf", symbol="Callout_expandButtonOverSkin");    upSkin: Embed(source="/assets/skins.swf", symbol="Callout_expandButtonUpSkin");   }  </fx:Style>    <fx:Script>   <![CDATA[    private var _data:Object;        [Bindable]    // implement IDataRenderer    public function get data():Object    {     return _data;    }        public function set data(value:Object):void    {     _data = value;    }        private var _expr:String;          private function creationCompleteHandler():void    {     parent.addEventListener(MouseEvent.ROLL_OVER, rollOverHandler);     parent.addEventListener(MouseEvent.ROLL_OUT, rollOutHandler);    }        private function rollOverHandler(event:MouseEvent):void    {     if (currentState == "normal")     {      currentState = "titleState";     }    }        private function rollOutHandler(event:MouseEvent):void    {     if (currentState == "titleState")     {      currentState = "normal";     }    }        private function expandButton_clickHandler():void    {     currentState = "detailState";    }        private function closeButton_clickHandler():void    {     currentState = "normal";    }        private function effectStartHandler():void    {     parent.removeEventListener(MouseEvent.ROLL_OVER, rollOverHandler);    }        private function effectEndHandler():void    {               parent.addEventListener(MouseEvent.ROLL_OVER, rollOverHandler);    }                      ]]>  </fx:Script>    <s:states>   <s:State name="normal"/>   <s:State name="titleState"/>   <s:State name="detailState"/>  </s:states>    <s:transitions>   <s:Transition fromState="*" toState="*">    <s:Resize duration="250"        effectEnd="effectEndHandler()"        effectStart="effectStartHandler()"        target="{this}"/>   </s:Transition>  </s:transitions>    <s:HGroup id="titleBar"      width="100%"      height="30%"      verticalAlign="middle">   <mx:Image id="pieChartImage"       width="5" height="5"       source="@Embed(source='/assets/ColumnChart2.png')"/>   <s:Label id="titleLabel"      fontSize="10"      fontWeight="bold"      includeIn="titleState,detailState"      text="{data.getItemAt(0).NAME}"/>   <mx:Button id="expandButton"        width="18" height="18"        click="expandButton_clickHandler()"        includeIn="titleState"        styleName="InfoExpandButton"/>   <mx:Spacer width="100%" includeIn="detailState"/>   <mx:Button id="closeButton"        width="18" height="18"        click="closeButton_clickHandler()"        includeIn="detailState"        styleName="InfoCloseButton"/>  </s:HGroup>   <mx:ColumnChart id="columnchart" showDataTips="true" selectionMode="multiple"   width="150" height="150"      dataProvider="{data}"       includeIn="detailState"     >   <mx:horizontalAxis   >    <mx:CategoryAxis id="categoryaxis" dataProvider="{data}" categoryField="NAME"  />   </mx:horizontalAxis>   <mx:series>    <mx:ColumnSeries interactive="true" labelField="NAME" id="column1"         displayName="2007" xField = "NAME" yField="TOTAL07"          dataProvider="{data}"/>        <mx:ColumnSeries interactive="true" labelField="NAME" id="column2"         displayName="2009" xField = "NAME" yField="TOTAL09"          dataProvider="{data}"/>       </mx:series>   </mx:ColumnChart>   <mx:Legend dataProvider="{data}" scaleX="0.3" scaleY="0.3"/>            </s:VGroup>
by Anonymous User
Not applicable
Original User: sumof2cubes
[ATTACH=CONFIG]22844[/ATTACH]
The same thing happens to the ESRI example until you mouseover one of the infoRenderers.  Does yours bring the mouseover infoRenderer to the front?  This could help lead to a resolution.
ionarawilson1
I tried everything and I suspect that there is something wrong with my feature layer. Can you guys please take a look and let me know what I should do different in my layer? I am not including all the fields because it would be tool long but here is the layers for comparison
Thanks!
My layer
http://tfsgis-iisd01:6080/arcgis/rest/services/Economic_Impacts_Trends/TrendsServiceYearsJoined/MapS...
Layer: EconomicImpactsTrends.TRENDSEDITOR.Ecoimpacts_trends_07_09_Joined (ID: 0)
Display Field: NAME
Type: Feature Layer
Geometry Type: esriGeometryPoint
Description:
Definition Expression:
Copyright Text:
Default Visibility: true
MaxRecordCount: 1000
Supported Query Formats: JSON, AMF
Min Scale: 0
Max Scale: 0
Supports Advanced Queries: true
Supports Statistics: true
Has Labels: false
Can Modify Layer: false
Can Scale Symbols: false
Extent:
    XMin: -1.06862384587E7
    YMin: 3485785.890299998
    XMax: -1.04354477563E7
    YMax: 3978750.918700002
    Spatial Reference: 102100  (3857)
Drawing Info:
    Renderer:
        Simple Renderer:
        Symbol:
            Style: esriSMSCircle
            Color: [0, 122, 140, 255]
            Angle: 0.0
            XOffset: 0
            YOffset: 0
            Outline:
                [0, 0, 0, 255] Width: 1 Label:
        Description: Transparency: 0
    Labeling Info:
HasZ: false
HasM: false
Has Attachments: false
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
Type ID Field: null
Fields:
    OBJECTID_12 ( type: esriFieldTypeOID , alias: OBJECTID_12 )
    OBJECTID_1 ( type: esriFieldTypeDouble , alias: OBJECTID_1 )
    NAME ( type: esriFieldTypeString , alias: NAME , length: 32 )
    CNTY_FIPS ( type: esriFieldTypeString , alias: CNTY_FIPS , length: 3 )
    FIPS ( type: esriFieldTypeString , alias: FIPS , length: 5 )
    OBJECTID ( type: esriFieldTypeDouble , alias: OBJECTID )
    NAME_1 ( type: esriFieldTypeString , alias: NAME_1 , length: 15 )
    ForDirIndO ( type: esriFieldTypeDouble , alias: ForDirIndO )
    ForDirEmp ( type: esriFieldTypeDouble , alias: ForDirEmp )
Supported Operations:   Query   Generate Renderer   Return Updates
And here is the ESRI layer
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...
Layer: Cities (ID: 0)
Display Field: CITY_NAME
Type: Feature Layer
Description: This service presents census information for U.S. cities and states including total population, racial counts, and more. It also includes rivers.
Copyright Text: (c) ESRI and its data partners
Min. Scale: 0
Max. Scale: 0
Default Visibility: True
Extent:
    XMin: -158.064605712891
    YMin: 19.6961498260498
    XMax: -67.986768734036
    YMax: 64.8691042579708
    Spatial Reference: 4326
Has Attachments: False
HTML Popup Type: esriServerHTMLPopupTypeNone
Drawing Info:
    Renderer:
        Simple Renderer:
        Symbol:
            Simple Marker Symbol:
            Style: esriSMSCircle, Color: [156, 173, 0, 255], Size: 4, Angle: 0, XOffset: 0, YOffset: 0
            Outline
                Color: [0, 0, 0, 255], Width: 1Label:
        Description:
    Transparency: 0
    Labeling Info: N/A
Fields:
    FID (Type: esriFieldTypeOID, Alias: FID)
    Shape (Type: esriFieldTypeGeometry, Alias: Shape)
    CITY_FIPS (Type: esriFieldTypeString, Alias: CITY_FIPS, Length: 5 )
    CITY_NAME (Type: esriFieldTypeString, Alias: CITY_NAME, Length: 40 )
    STATE_FIPS (Type: esriFieldTypeString, Alias: STATE_FIPS, Length: 2 )
    STATE_NAME (Type: esriFieldTypeString, Alias: STATE_NAME, Length: 25 )
    STATE_CITY (Type: esriFieldTypeString, Alias: STATE_CITY, Length: 7 )
    TYPE (Type: esriFieldTypeString, Alias: TYPE, Length: 25 )
    CAPITAL (Type: esriFieldTypeString, Alias: CAPITAL, Length: 1 )
    ELEVATION (Type: esriFieldTypeSmallInteger, Alias: ELEVATION)
    POP1990 (Type: esriFieldTypeInteger, Alias: POP1990)
    HOUSEHOLDS (Type: esriFieldTypeInteger, Alias: HOUSEHOLDS)
    MALES (Type: esriFieldTypeInteger, Alias: MALES)
    FEMALES (Type: esriFieldTypeInteger, Alias: FEMALES)
    WHITE (Type: esriFieldTypeInteger, Alias: WHITE)
    BLACK (Type: esriFieldTypeInteger, Alias: BLACK)
    AMERI_ES (Type: esriFieldTypeInteger, Alias: AMERI_ES)
    ASIAN_PI (Type: esriFieldTypeInteger, Alias: ASIAN_PI)
Type ID Field: N/A
Supported Interfaces:   REST
by Anonymous User
Not applicable
ionarawilson1
Thank you so much Justin. Your observation made me compare more the code I was running with the code in the ESRI site, and I realized that the SDK should be 4.5.1A and the library should be agslib 2.5. I was using SDK 4.6 and Esri library. 3.0.
I think the issue of seeing the symbol overlapped with the ESRI sample only happens  if you open the icon for Fairbanks, then open the icon for Anchorage, then close the icon for Fairbanks, right? It just appears for a few seconds, then it disappears when you mouse over anywhere else. I think that part is ok, my problem was that the icon below was just overlapping on top of the infowindow I opened, but it looks like the ESRI sample now! Thank you so much for helping me!!!
