Change Cursor Over Zoom Slider
903
04-16-2010 09:50 AM
JoshObrecht
I am trying to change the cursor when it goes over the zoom slider.  Is this possible or is the zoom slider directly a part of the map and has to use the cursor associated with the map?
Thanks.
CristianJonhson
Hello, did u discover how to solve this problem? Can u give us a feedback about that?
Thanks in advance,
Cristiano Benato.
RobertScheitlin__GISP
Guys,
    This is not to hard to do but you will have to extend the navigation class to do it.
add this code as a mxml component called MyNavigation.as. It has to be in a com/esri/ags/samples folder.
package com.esri.ags.samples
    import com.esri.ags.controls.Navigation;
    import flash.events.Event;
    import flash.events.MouseEvent;
    import mx.managers.CursorManager;
    public class MyNavigation extends Navigation
     [Embed(source="assets/images/cursors/draw_cursor.png")]
  private var lineCursor:Class;
        public function MyNavigation()
            navigationSliderClass = MyNavigationSlider;
        override protected function initializationComplete():void
         this.addEventListener(MouseEvent.MOUSE_OVER, setCur);
         this.addEventListener(MouseEvent.MOUSE_OUT, remCur);
        private function setCur(evt:Event):void
         CursorManager.setCursor(lineCursor,1);
        private function remCur(evt:Event):void
         CursorManager.removeCursor(CursorManager.currentCursorID);
Then where your map component is make it look like this.
<esri:Map id="map" navigationClass="com.esri.ags.samples.MyNavigation">
CristianJonhson
Thanks for your answer Robert...
Att.,
Cristiano Benato.
