Can you add records to a Query's ExecuteLastResult?
914
06-02-2010 09:32 AM
BrendanLee
Is it possible to add to the executeLastResult set? I want to perform a query and allow the user to add or remove from the returned set. I also have a datagrid that is bound to the executeLastResult set and want it to update as records are added or deleted.
Can I somehow reference the graphics layer that I am adding and deleting graphics on?
dataProvider="{myGraphicsLayer.graphicProvider}" .... or something?
Any help or suggestions would be greatly appreciated.
Thanks!
SiminYou
I used a ArrayCollection to store the query results, then I could dynamically change records.
BrendanLee
I got it to work:
<esri:GraphicsLayer id="myGraphicsLayer" graphicRemove="updateGrid()" graphicAdd="updateGrid()"/>
private function updateGrid():void
  // Clear grid
  dg.dataProvider.removeAll();
  results = new ArrayCollection;
  for (var i:int = myGraphicsLayer.numGraphics - 1; i >= 0; i--)
      var g:Graphic = myGraphicsLayer.getChildAt(i) as Graphic;
      results.addItem({PARCEL:g.attributes.PARCEL, OWNER:g.attributes.OWNER, STRNO:g.attributes.STRNO, STRNAME:g.attributes.STRNAME, STRTYPE:g.attributes.STRTYPE})
  lblParCount.text = results.length.toString();
  dg.dataProvider=results;
