Can FindTask query more than 1 map?
1443
08-31-2011 12:33 PM
AshleyOwens
I would like to have the user select a layer from one map, then select all layers (possibly from other maps) they want to see that intersect the first map. I know FindTask can query a map and multiple layers, but can it query multiple maps?
Thanks!
Ashley
RobertScheitlin__GISP
Ashley,
   No the FindTask can only search one Map Service (not map) at a time. If you want to search multiple map services than you will just have to loop through them.
AshleyOwens
Thanks Robert.
I'd like to make sure I'm using the right approach. Here are the basic steps I'd like to include:
1. Select an object from Map Service 1.
2. Select intersecting layers of object (from step 1) from Map Services 2, 3 & 4.
3. Extract object & intersecting data from all chosen Map Services & layers into a file.
I know how to do step 3, but I'm not quite sure how to
a. determine when objects are intersecting, and
b. get results from more than 1 Map Service into 1 result set
Is the spatial portion of the existing Search Widget a good starting point for this functionality? Would the Data Extract widget be better? (http://help.arcgis.com/en/webapps/flexviewer/help/index.html#//01m300000025000000)
Thanks so much for your help!  --ashley
Ashley,
   The existing search widget would be the way to go as it fires off a spatial Query using a graphic and returns graphics.
AshleyOwens
I am using the existing Search widget code and am unable to loop through multiple map services. I believe this is the sequence of functions that is called in the existing Search widget:
1. queryFeaturesSpatial()
2. queryFeaturesSpatial(), onResult()
3. bufferGeometries()
4. bufferGeometries(), bufferCompleteHandler()
5. queryFeaturesGraphical()
6. queryFeaturesGraphical(), onResult()
7. createSearchResults()
8. createSearchResults(), displayFields()
I have tried putting a hardcoded call to function queryFeaturesSpatial using another map service, but it stops in function bufferGeometries.
Has anyone else tried to do this?
