Call dynamically services from arcgis service directory
1456
02-15-2012 02:08 AM
Mohammed_YassineAYACHE
Hi everybody,
Is there a method to know the list of services published in a folder of the arcgis services directory ?
I want to call dynamically the services existing in this directory. the pupose is that when a new service is published, the application load it automatically without changing the code.
is that possible ?
IvanBespalov
Server version "10.01" returns description for each folder: Folder Louisville in ESRI sample server
{"currentVersion" : "10.01",    "folders" : [],    "services" : [     {"name" : "Louisville/LOJIC_LandRecords_Louisville", "type" : "MapServer"},      {"name" : "Louisville/LOJIC_PublicSafety_Louisville", "type" : "MapServer"}   ] }
Here is help
All you need is experience with parsing server response in JSON format.  🙂
IvanBespalov
Here is help
Thanks a lot Ivan.
but still not understanding how to retrieve the server response with flex. which Object shall I use (HttpService ?).
Regarding JSON, I have no problem, I use it all the time.
it works with HttpService.
thanks again 🙂
