Zoom to selected row of DataGrid in QueryBuilderWidget of FlexViewre1.3
2064
11
04-07-2010 02:12 AM
Shimonchh
I am working on QueryBuilderWidget of FlexViewer 1.3.I want to zoom the selected row of DataGrid which is populated with the result of query.
Now when I write map.centerAt map doesn???t displayed but map point of corresponding DataGrid row is highlighted.While map.centerAt is working for another widgets.
if (map.scale > zoomScale)
map.scale = zoomScale;
map.centerAt(MapPoint(gr.geometry));
map.infoWindow.styleName = "myInfoWindow";
map.infoWindow.show(MapPoint(gr.geometry) );
map.infoWindowContent=vBoxData;
please suggest me some way to center the map at selected map point.
RobertScheitlin__GISP
shimon31,
    Not seeing all your code it is hard to say where you are going wrong. Here is some code to handle points, lines and polygons.
add this import:
import mx.events.ListEvent;
add these new functions:
private function findGraphicByAttribute(attributes:Object):Graphic
    for each( var graphic:Graphic in mqGraphicsLayer.graphicProvider)
      if ( graphic.attributes === attributes)
        return graphic;
    return null;
  private function onItemClick(event:ListEvent):void
   var gra:Graphic = findGraphicByAttribute(event.itemRenderer.data);
   var pt:MapPoint = null;
   var sIcon:String="";
   if (gra.geometry is MapPoint){
    pt = gra.geometry as MapPoint;
    if (map.scale > 5000)
     map.scale = 5000;
    map.centerAt(pt);
   } else if (gra.geometry is Polygon) {
    pt = new MapPoint();
    pt.x = (gra.geometry.extent.xmax + gra.geometry.extent.xmin) / 2
    pt.y = (gra.geometry.extent.ymax + gra.geometry.extent.ymin) / 2
    sIcon = ICON_URL + "i_info.png";
    map.extent = gra.geometry.extent;
   }  else if (gra.geometry is Polyline){
    var polyline:Polyline = gra.geometry as Polyline;
                pt = polyline.extent.center;
   if (pt != null){
     var sContent:String = "";
     var obj:Object = gra.attributes
     var fld:String;
     var value:String;
     for (fld in obj)
            value = obj[fld].toString();
            sContent = (sContent.length == 0)? fld  + " = " + value + "<br/>" :
                    sContent +  fld + " = " + value + "<br/>";
     var infoData:Object =
     icon : sIcon,
     content: sContent,
     point: pt,
     link: ""
    this.showInfoWindow(infoData);
Change the datagrid:
<mx:DataGrid id="QBData" width="100%" height="100%" itemClick="onItemClick(event)" />
Shimonchh
Thanks for your help sir.
But still the problem remian same.Actually when map is centered at corresponding point then infowindow is displayed at proper position but  map is not displayed.I have tried your suggested code also.Map.centreAt is working with search widget but not working with QueryWidget.
Please suggest some another method.
shimon31,
   Lets check for for the simple stuff.
     map.scale = 5000;
    map.centerAt(pt);
The scale of 5000 add one more zero like this:
    if (map.scale > 50000)
     map.scale = 50000;
    map.centerAt(pt);
It is probably that you basemaps are not able to draw down to that scale.
Shimonchh
map.scale=zoomscale works but when i write map.centerAt(pt) map disappeared but infowindow is displayed .
Is it possible to display infowindow without centering the map at pt.Actually i tried but it didn't work.
I very confused same code is working somewhere else but not here.Is there any prerequisite of map.centerAt function.
Shimonchh
When i try  zoom to query result then again same  problem occurs. when i write
map.extent = multiPoint.extent.expand  again map doesn't displayed.Is there problem with map or with my code.
if (fset != null){
     switch(fset.geometryType)
             case Geometry.MAPPOINT:
              var multiPoint:Multipoint = new Multipoint();
              for each (var gra:Graphic in  fset.features) {
               multiPoint.addPoint(MapPoint(gra.geometry));
              if (multiPoint.points.length > 1){
               map.extent = multiPoint.extent.expand(1.5);
        else{
         map.centerAt(multiPoint.points[0]);
        break;
             case Geometry.POLYLINE:
                 break;
             case Geometry.POLYGON:
                 var unionExtent:Extent;
        var firstGra:Graphic = fset.features[0];
        unionExtent = Polygon(firstGra.geometry).extent;
        for each (var selectGra:Graphic in fset.features){
         unionExtent = unionExtent.union(Polygon(selectGra.geometry).extent);
        map.extent = unionExtent.expand(1.5);
                 break;
Shimon31,
  I still think that you are having a spatial reference issue try putting a trace statement in your for loop.
trace("Map SR: " + map.spatialReference.toString());
trace("Gra SR: " + gra.spatialReference.toString());
else{
MattGiles
Hi Robert,
I am trying to use the code you provide in this thread to zoom to my points when i click on them in my datagrid. A problem exists in the findGraphicByAttribute() function: The if ( graphic.attributes === attributes) statement is never entered (because the attirbutes of the graphics in myGraphicsLayer never matches the attribute variable (event.itemRenderer.data sent from clickHandler(event:ListEvent)). Ive been trying to figure out why the attribute object would not match the attributes of the graphics within myGraphicsLayer and the only thing i can think of is that the attributes are not sent properly through the ListEvent. My datagrid uses dataProvider="{findTask.executeLastResult}". Could this be? Are there any other reasons why this could happen?
M Giles,
   I don't think that the attributes will ever match using the
That is just a shortcut way of getting data into a dataprovider and is not going to match with === equality to an graphics.attributes.
MattGiles
Can you briefly describe how I could load the datagrid so that i can zoom to and display popups...I have tried setting the dataProvider = fs where fs is an array populated from FindEvent.findResults but that doesnt work either - is this the same thing??
