Buffer multiple points - NON-SFV convert from 1.3 to 2.0
1002
08-31-2010 06:38 AM
CarmenDurham
I'm still converting a non-SFV flex app fro 1.3 to 2.0, FB4 and SDK4 (with 9.31 services).
Using a buffer geometry service that buffers multiple address points by 500ft and then select fire hydrants within that distance.  Worked in 1.3.  Process will work in 2.0 if I just have one address, the issue is multiple addresses.
1.3 code ( fullAddressGraphictoBuffer:Array and addressLayer: GraphicsLayer):
 fullAddressGraphictoBuffer = ArrayCollection(addressLayer.graphicProvider).toArray();
 var bufferParameters:BufferParameters = new BufferParameters();
 bufferParameters.features = fullAddressGraphictoBuffer;
2.0 code -  I think it has something to do with the fullAddressGraphictoBuffer being an array of graphics vs. geometries, but I don't know how to "get to" the geometries of a graphicsLayer.
  bufferParameters.geometries = fullAddressGraphictoBuffer;
// this works for single address bufferParameters.geometries = [lastAddressGraphic.geometry];
Is this where featureLayer may work better?
RobertScheitlin__GISP
Carmen,
   You just have to loop through the graphicsProvider and create an array of geometries from it.
var geoArray:Array = [];
for each(var gra:Graphic in fullAddressGraphictoBuffer){
    geoArray.push(gra.geometry);
bufferParameters.geometries = geoArray;
CarmenDurham
Thanks Robert!  Worked like a charm.
Carmen
