Flex Viewer 2.0 Beta - Live Layer
1126
07-06-2010 05:30 AM
BernardLachance
In version 1.3 there was Live Layer Widget but i can't see it in the new version. Can you tell me if it's going to be available in the final release? If not, what is the best way to show a live layer with the new version of the Flex Viewer
Thanks!
RobertScheitlin__GISP
Bernard,
   Look here for the answer
http://help.arcgis.com/en/webapps/flexviewer/help/faq.htm
ShaningYu
Honored Contributor
Robert:
I tried to update my customized Flewviewer using API 2.0. but got a lot of errors.
The error look likes:
component SimpleMarkerSymbol is defined more than once in this namespace.  Remove the mapping to com.esri.ags.symbol:SimpleMarkerSymbol or com.esri.ags.symbols:SimpleMarkerSymbol Flexviewer
It is really hard to debug them.  I guess these bugs should be fixed in Flexviewer 2.0 Beta.  Could you provide the site where I can download the source code of 2.0 Beta?  Thanks.
Yours,
Shaning
BjornSvensson
Esri Alum
The source code for the Flex Viewer 2.0 beta can be downloaded from http://help.arcgis.com/en/webapps/flexviewer/ - look for the link on the right side that says "Download source code for Viewer".
Also note that when upgrading from the 1.x API to the 2.x API, we listed some migration steps in the "Migrating to 2.0" topic - http://help.arcgis.com/en/webapi/flex/help/index.html#migrating.htm
e.g.
"The package "symbol" has been renamed to symbols to follow Flex 4 syntax."
