Bing and Sample Flex Viewer (v 1.3)
1379
05-12-2010 11:28 AM
SusanMordy1
I have been provided with the following information from our ArcGIS server administrator:
http://servername/pub/vet/jsp/vetoken.jsp
for using Bing in Flex.
The resource center provides the following document for using Bing Maps in Flex:
http://resources.esri.com/help/9.3/arcgisserver/apis/flex/help/index.html#ve_gettingstarted.htm?
In the config.xml file for the sample flex viewer (v 1.3) there is mention of bing:
//uncomment lines below to view virtual earth maps;comment arcgisonline map configuration above (elements: map, basemaps, mapservice)
<!--map initialExtent="-1.3861396457346804E7 2959641.7352047404 -8172035.568026077 6452508.179723226" fullExtent="-1.2836528782099428E7 -4344069.191498438 9920914.775183456 9627396.586575491">
<basemaps menu="menuMap">
      <mapservice label="Road" type="virtualearth" visible="true" style="road" alpha="1" icon="com/esri/solutions/flexviewer/assets/images/icons/i_globe.png">http://[machine]/vetoken.ashx</mapservice>
      <mapservice label="Aerial" type="virtualearth" visible="false" style="aerial" alpha="1" icon="com/esri/solutions/flexviewer/assets/images/icons/i_globe.png">http://[machine]/vetoken.ashx</mapservice>
</basemaps-->
I am not sure what I specifically need to change to the sample flex viewer code (v 1.3) and what specific additional information I will need from my ArcGIS server administrator.
Thanks for you help,
Susan
SusanMordy1
Has anyone got their Bing service working with the SFV 1.3 and could provide an example?
Susan
GarrettMcBride
Please if anyone has any helpful insight to how to get bing to work please email me.  I can't find any real documentation to get this to work.  Everything i have tried has been trial in error with no luck.  The maps do not appear but i still get an x/y coordinate and can still search and locate cities with correct coordinates.  I have to be close.  I commented out the ESRI basemaps and then uncommented out the Bing.  I then exported out a vetoken.ashx and put it in my IIS configured with user name and password that i got via ArcSOM.  When you go directly to the vetoken (http://domain/vetoken.ashx)  it gives a token (ex {"token":"mqc8vRfhMmisbouPhkvibwB6Etl_feVl9J5ET15qsjKzHQ3qqv4PVk4JqNLYq0bx2WgE2XXNnaKX-a8UljHp6w2"} )  which makes me think i am leaving out something small.  Any help would be greatly appreciated.
Garrett McBride
Email: [email protected]
ChrisClose
Please follow these steps to get access to BING maps in the Sample Flex Viewer (SFV) v 1.3 (these instructions assume the SFV is set up in the IIS wwwroot folder):
1. Open the config.xml file and comment out the original map tag. Below is what the code should look like:
  <!--map initialExtent="-122.2 24.89 -70.59 46.92" fullExtent="-150 -50 150 50">
                  <mapservice label="Street Map" type="tiled" visible="true" alpha="1" icon="com/esri/solutions/flexviewer/assets/images/icons/i_highway.png">http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer</mapservice>
                  <mapservice label="Satellite Map" type="tiled" visible="false" alpha="1" icon="com/esri/solutions/flexviewer/assets/images/icons/i_shuttle.png">http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_Imagery_World_2D/MapServer</mapservice>
      </basemaps-->
2.  Uncomment the secondary map tag.  Be sure to comment OUT the first line - the line starts with "//".  Below is what the code should look like:
  <!--//uncomment lines below to view virtual earth maps;comment arcgisonline map configuration above (elements: map, basemaps, mapservice)-->
      <map initialExtent="-1.3861396457346804E7 2959641.7352047404 -8172035.568026077 6452508.179723226" fullExtent="-1.2836528782099428E7 -4344069.191498438 9920914.775183456 9627396.586575491">
      </basemaps>
3.  At the end of each map service url above, there is a link to the vetoken file.  Change the [machine] in the http://[machine]/vetoken.ashx to match your machine.  For example:
http://yourmachine/vetoken.ashx
4. Save the file.
5. Copy the vetoken.ashx file to your wwwroot dir.  For example: "C:\Inetpub\wwwroot"
Notes:
- If this file in any other folder, you will not be able to access BING maps
- To get a copy of this file, see Step 2 in the help: http://resources.esri.com/help/9.3/arcgisserver/apis/flex/help/index.html
6. Edit the vetoken.ashx to add your username and password and your host machine.  The following areas need changed: "your username", "your password", and "yourmachine" as illustrated below:
    // set your VE credentials
    private string userName = "your username";
    private string password = "your password";
    // set your allowed referers
    // For ex.: "http://www.esri.com/myapp/"
    private string[] refererURLs = {
                                     "http://yourmachine",
                                     //"http://[replace]",
7. Save the file
8. Open a browser and test app.
