Flex Viewer 2 Suggestions
973
07-14-2010 07:57 AM
BrianBehling
Hello.
Is there somewhere developers can go to make requests for changes to the Flex Viewer 2 beta app?
There are a couple of changes I think would be beneficial to make the app a little more user friendly. I can always make these changes in the source code, but these changes should be in the default app as well.
JoshuaKalov
They may have a better/preferred  place for Flex Viewer suggestions, but one place you could use is the ArcGIS Server Ideas site.
http://ideas.arcgis.com/ideaList?c=09a300000004xET&category=ArcGIS%20Server
BjornSvensson
Esri Alum
To submit bugs or enhancements, the best way is to report it to ESRI Support - http://support.esri.com/en/.  This also allows you to keep track of it's progress, as well as someone from ESRI to follow-up with you in case of questions related to your bug/enhancement/suggestion.
A second option is to submit it at http://ideas.arcgis.com.  This allows other users to "vote" for it as well.
A third option is to post in the forum and hope that someone on the development team see's it.
