Attributetable, limit columns
1099
12-17-2012 08:58 AM
AaronNash1
is there a way to limit the columns dispalyed in the attributetable?
thanks,
HeatherGonzago
thanks,
What exactly do you mean when you state "limit the columns"?
Are you doing this directly using the AttributeTable component or in the Viewer?
AaronNash1
When i use the attributetable component and reference my featurelayer, all the outfields are put into columns. I only want to show a few of the columns. I am using the attributetable component in my own application
SarthakDatt
Hey Aaron,
The Attribute Table component shows all the fields set as 'outfields' on the feature layer which by default is "*" (all fields). You can set the outfields to the fields you want and the component would reflect that.
