Attribute inspector not editable?
4089
09-11-2014 02:17 PM
ionarawilson1
I have an application that is using the editor and the attribute inspector. I need to add a string showing the current date to a field. Everything works but after creating the feature and selecting it again I can see the string in that field in the attribute inspector but the attribute inspector is not editable anymore for that feature. Is it possible to add a string to a field and still have that feature editable in the attribute inspector? Thanks
var    currDateTime:String = ""
private function drawEnd(event:DrawEvent):void
                dateFormatter.formatString = 'YYYY/MM/DD HH:NN:SS';
                var dtCurrent:Date = new Date();
               currDateTime = String(dateFormatter.format(dtCurrent) + '.' + dtCurrent.getMilliseconds());
               myFeatureLayerstewardship.addEventListener(FeatureLayerEvent.EDITS_STARTING, editsStartingHandler);
            private function editsStartingHandler(event:FeatureLayerEvent):void
                if (event.adds)
                    event.adds[0].attributes['DrawDate']  =  currDateTime;
ionarawilson1
I fixed the issue! Just create a editscomplete event and refresh the feature layer and the attribute inspector!
protected function myFeatureLayerstewardship_editsCompleteHandler(event:FeatureLayerEvent):void
                myFeatureLayerstewardship.removeEventListener(FeatureLayerEvent.EDITS_STARTING, editsStartingHandler);
              myFeatureLayerstewardship.refresh();
              myEditor.attributeInspector.refresh();
ionarawilson1
