ArcGIS Geoprocessing Service results updates as porgress
3077
07-31-2013 01:23 AM
MohammadIshfaq
Greetings all,
I am trying to run a long (processing multiple objects in a batch mode) and heavy processing (raster manipulation) operation through ArcGIS Geoprocessing Service. It is working fine in execute synchronous or asynchronous operation, however, I would like to get the status update messages while geoprocessor is executing and show them as progress using ArcGIS silverlight or ArcGIS flex client.
I would appreciate if anyone can provide a clue, any literature or POC in this regard. In advance, I thank you all for your time and support.
RobertScheitlin__GISP
Mohammad,
   I don't have a full example but if you look at the documentation then you will see that you can add an event listener for STATUS_UPDATE and get the JobInfo
Docs:
https://developers.arcgis.com/en/flex/api-reference/com/esri/ags/events/GeoprocessorEvent.html
geoprocessTask.addEventListener(GeoprocessorEvent.STATUS_UPDATE, statusUpdateHandler);
And get the JobInfo from that event to get the
jobStatus and messages
Docs:
https://developers.arcgis.com/en/flex/api-reference/com/esri/ags/tasks/supportClasses/JobInfo.html
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
Mohammad,
Docs:
Docs:
MohammadIshfaq
Thanks Robert for your prompt help. I would give it a shot and let you know regarding the output and accordingly mark it as an answer if it serve the purpose :).
Regards.
MohammadIshfaq
I was able to test both of these objects with Silverlight and it worked like a charm. Thanks Robert once again for your kind help. It indeed helped regarding what I was looking for.
Regards.
