ArcGIS API for flex over an Android emulator
1014
07-05-2012 11:04 PM
MostafaFouly
I have been trying to test a sample application using ArcGIS APIs for Flex over an emulator for android or iOS and not on a device, (Run -> Run configurations -> On desktop), it's not working though.
So do we have to test the flex apps over a device not an emulator? isn't it supported to test it over an emulator instead?
thx!
mostafa.
BjornSvensson
Esri Alum
You can use the built-in emulator with Adobe Flash Builder using the "On desktop" launch mode.  You do not have to have the device to do this.
BjornSvensson
Esri Alum
AaronNash
what version of flash builder are you running? if its 4.5.1 or 4.6 you need to make sure you are in a mobile project and then you should be able to run Adobe's flash builder mobile emulator. It is seperate than the Android SDK emulator.
