Anno and the Legend Widget
2663
01-21-2011 06:09 AM
Drew
Has anyone had any problems with Anno and the Legend Widget?
I am getting an error when the legend widget is open and I Pan around.
There error is in the API itself ??? suspect this is a bug
ERROR:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at com.esri.ags.skins::LegendSkin/findLeafLayerLegendInfo()
at com.esri.ags.skins::LegendSkin/extentChangeHandler()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at mx.core::UIComponent/dispatchEvent()
at com.esri.ags::Map/http://www.esri.com/2008/ags/internal::dispatchPanEnd()
at PanHandler/enterFrameHandler()
Drew
IsharaKotiah
Andrew
I have experienced the same issue. Tried a map service with no anno and it worked fine. I agree it must be a bug.
Ishara
BjornSvensson
Esri Alum
Yes, it's a bug in the Legend component.  We are planning to fix it for the next release (version 2.3).
NageshNangi
Similar issue is seen in JavaScript API 3.4. In 3.1 version it was working fine.
