adobe flex code keep loading
4301
11-17-2014 05:44 PM
LiYao
‌Hello everybody,
I am using adobe flash builder to create a widget. The widget should load a datagrid with the data retrieved by ASP.NET, but when I click the widget, it keeps loading.
My code is as the following:
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()">
  <mx:Script>
  <![CDATA[
  import mx.controls.Alert;
  import mx.rpc.events.FaultEvent;
  import mx.rpc.events.ResultEvent;
  public function init():void {
  // Get Data from WebService and fill datagrid when you first invoke the application
  ws.GetLoc();
  public function GetLoc(event:ResultEvent):void {
  // Databind data from webservice to datagrid
  datagrid.dataProvider = event.result;
  public function fault(event:FaultEvent):void {
  // Oppps some error occured
  Alert.show(event.toString());
  </mx:Script>
  <mx:WebService id="ws" wsdl="http://localhost/TestWebService/Service.asmx?WSDL" fault="fault(event)">
  <mx:operation
  name="GetLoc"
  resultFormat="object"
  result="GetLoc(event)"
  </mx:WebService>
  <mx:Panel x="41.5" y="66" width="714.5" height="237" layout="absolute" title="Results">
  <mx:HBox height="95%" width="95%" horizontalCenter="0" verticalCenter="0">
  <mx:DataGrid id="datagrid" width="680" height="100%">
  <mx:columns>
  <mx:DataGridColumn headerText="Item No" dataField="ItemNo"/>
  <mx:DataGridColumn headerText="Sub Type No" dataField="SubTypeNo"/>
  <mx:DataGridColumn headerText="Item Name" dataField="ItemName"/>
  <mx:DataGridColumn headerText="Arrival Date" dataField="ArrivalDate"/>
  </mx:columns>
  </mx:DataGrid>
  </mx:HBox>
  </mx:Panel>
</mx:Application>
No idea on it, is there anything wrong with my code? I am using Adobe flash builder 4.6
Thanks a lot.
Message was edited by: Robert Scheitlin, GISP
RobertScheitlin__GISP
Li Yao,
  Ok, you are mixing things up here. If you are talking about using any of this code in the ArcGIS Viewer for Flex, then you are in the wrong forum and your code is totally incorrect. If you are not talking about coding in the ArcGIS Viewer for Flex then a question of using the WidgetTemplate is irrelevant. If you are doing custom coding for the Flex API (not using ArcGIS Viewer for Flex) then you use the base component mx:Application is correct.
If you are just custom coding for the Flex API then here is your code updated to Spark (where appropriate):
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:s="library://ns.adobe.com/flex/spark"
               xmlns:mx="library://ns.adobe.com/flex/mx"
               minWidth="955" minHeight="600">
    <fx:Declarations>
            <mx:operation
                name="GetLoc"
                result="GetLoc(event)"/>
        </mx:WebService>
    </fx:Declarations>
    <fx:Script>
        <![CDATA[
            import mx.collections.ArrayCollection;
            import spark.components.Alert;
                ws.GetLoc();
                datagrid.dataProvider = new ArrayCollection(event.result as Array);
    </fx:Script>
    <s:Panel x="41.5" y="66" width="714.5" height="237" title="Results">
        <s:HGroup height="95%" width="95%" horizontalCenter="0" verticalCenter="0">
            <s:DataGrid id="datagrid" width="680" height="100%">
                <s:columns>
                    <s:ArrayList>
                        <s:GridColumn headerText="Item No" dataField="ItemNo"/>
                        <s:GridColumn headerText="Sub Type No" dataField="SubTypeNo"/>
                        <s:GridColumn headerText="Item Name" dataField="ItemName"/>
                        <s:GridColumn headerText="Arrival Date" dataField="ArrivalDate"/>
                    </s:ArrayList>
                </s:columns>
            </s:DataGrid>
        </s:HGroup>
    </s:Panel>
</s:Application>
Li Yao,
  This one has me confused. Your title was "adobe flex widget keep loading", so I moved it to the ArcGIS Viewer for Flex‌ space then I see that the code has mx:Application (which means it is not a widget) so I moved it back to the ArcGIS API for Flex‌ space. But then I read more of you comments and you say
Which make me wander if you are actually talking about an ArcGIS Viewer for Flex widget and you just are very confused about widget development... Can you be more concise as to whether you are asking a question about an ArcGIS Viewer for Flex Widget or some custom Flex API code.
LiYao
Hi Robert,
I am asking the customized Flex API code.
Should I use WidgetTemplate instead of application.
Sorry for so many questions because I am just starting using Flex. Thanks a lot for the help.
Li Yao,
    <fx:Declarations>
            <mx:operation
                name="GetLoc"
        </mx:WebService>
    </fx:Declarations>
    <fx:Script>
        <![CDATA[
                ws.GetLoc();
    </fx:Script>
                <s:columns>
                    <s:ArrayList>
                    </s:ArrayList>
                </s:columns>
            </s:DataGrid>
        </s:HGroup>
    </s:Panel>
</s:Application>
LiYao
Hi Robert,
You are right, by using the updated code the problem not occur again. Thanks a lot.
