addTitlebarButton for widget template
1159
09-24-2011 12:26 PM
Shu-RongKuo
Hi.
I am new on Flex 3.  May someone tell me what addTitlebarButton method in widget template works ?
thanks so much for the help.
RobertScheitlin__GISP
Shu-Rong,
   Widget related questions belong in the Flex Viewer Forum:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
To answer your question: You will learn more about the inner workings of the Viewer by looking at the source code.
The addTitlebarButton function in a widget takes three properties
  1. A url to a icon
  2. A String that will be displayed as the tooltip when you hover over the button.
  3. A function that should be called when the button is clicked.
  4. and an optional forth which is a Boolean that indicates if the button is a toggle type or a standard button
Shu-RongKuo
Shu-Rong,
  1. A url to a icon
thanks so much.
