XML config file for Widget
906
09-20-2011 07:25 AM
Shu-RongKuo
Hi.
I am new on Flex and is working on Flex 3.
does every widget need XML config file, how this config file is used - I mean how the tags are processed and any specific tags.
thanks so much for the help.
DidumAbraham
Please post threads to ArcGIS Viewer for Flex at http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex.
Here is my suggestion for you, many of your questions will be self-explanatory if you so choose. Open concepts tab and read through getting started and as well as the files under concepts tab.  ESRI did an awesome job laying out many aspects of widget configurations and all associated files. This tab is seen at http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Getting_started/01m300000021000000/.
Shu-RongKuo
thanks for the help.
